7 Replies Latest reply on Feb 26, 2008 11:45 AM by n8thedesigner
    Problem starting Captivate
    n8thedesigner
      I installed the trial version of Captivate last week, tested for a few days, everything worked fine. Rebooted my computer this morning, ran Adobe Updater, tried to start Captivate and now the application freezes as soon as I try to open a project. I get past the splash screen and into the program, but on opening a file Captivate freezes before anything comes onto the screen. Here's what I've tried:
      Rebooting
      Re-installing Captivate
      Starting Captivate while disconnected from the network
      Any other ideas? I appreciate your help!
        • 1. Re: Problem starting Captivate
          CatBandit Level 3
          Welcome to the User Community. It sounds like you might need more help than we can give you, but I will do my best, Nate.
          You said that the freeze occurs when you try to open a project ... does that mean it does NOT freeze if you record a new one? I am wondering if perhaps the projects you already opened and saved are corrupted, not Captivate itself(?)
          Do not save to a network. Do not run Captivate from a network. Both should be done from local drive C:\
          If you want to save to a network drive, save your work on Drive C:\, shut down Captivate, then move/copy the file using Windows Explorer.
          Let us know if you have success, or not, and if so, what you did that helped. Thanks, and best of wishes,
          Larry
          • 2. Re: Problem starting Captivate
            n8thedesigner Level 1
            Thanks for the welcome, Larry-
            I've tried starting a new project, but have the same problems that occur when trying to open a current project. The window remains blank, and although I can roll over the buttons and the tooltips appear, none of them function. I can go to the help menu, but if I select "getting started tutorials" for example, nothing happens. If I try to close the program, nothing happens. I have to use the task manager to shut it down.
            Any ideas?
            • 3. Re: Problem starting Captivate
              Hi n8thedesigner and I too extend you a welcome to our community
              I believe that an update may have recently occurred to the Flash Player. I'm wondering if perhaps you have tried visiting the Adobe Flash Player site and ensured all the updates have been applied if that might change or otherwise help things. You may visit this page by clicking here.
              Sometimes you may even find you need to downgrade a player. To do this, usually an uninstaller is needed. This link should assist with that.
              Cheers... Rick
              • 4. Re: Problem starting Captivate
                jbradley88 Level 2
                You didn't explicitly mention doing so, so perhaps you need to recreate your Captivate configuration file. You may have a corrupted file that didn't get reset during the reinstall.
                Recreating the configuration file is step 4 in the following article:
                http://kb.adobe.com/selfservice/viewContent.do?externalId=kb402464&sliceId=1
                • 5. Re: Problem starting Captivate
                  Level 7
                  > your
                  > get
                  If you've tried that and it doesn't work, try updating your graphic card
                  driver to the latest version. Weird display issues like this are often fixed
                  this way.
                  Steve
                  Adobe Community Expert: eLearning, Mobile and Devices
                  My blog - http://stevehoward.blogspot.com/
                  • 6. Re: Problem starting Captivate
                    CatBandit Level 3
                    Interesting and seemingly all-encompassing TechNote, jbradley. Having read it, I cannot imagine something in there leading to a solution. Don't know how I missed that article earlier, but thanks for the link!
                    regards~
                    Larry
                    EDIT
                    ooops - should have read: "... I cannot image something in there not leading to a solution ..." I think my double-negative got mixed with my triple positive.
                    • 7. Re: Problem starting Captivate
                      Thanks so much! I uninstalled the flash player, reinstalled and now Captivate is working just fine. I appreciate your (and eveyone elses') time!!
                      -Nate
