Hi.
I originally posted this in the General Discussion forum, but
realized it may belong here instead.
I am trying to create a scrolling image area. The code I have
now recognizes the mouse coordinates *anywhere* on the screen (not
just over the scrolling area). I want the images to automatically
begin scrolling to the right without user interaction, no matter
where their mouse is. Currently, the images won't scroll on page
load if my mouse is anywhere on the left of the screen... even if
it's nowhere near the scroll area. I can see why that's happening,
given the code below, but how do I get around that??
I want to keep the functionality of the actual scrolling area
as it is now when you hover your mouse in the active Flash area.
For example: moving the mouse left or right scrolls the images
correctly and they slow/stop when the mouse is in the center of the
Flash image area. That part is fine.
I just need some code that will initiate the images to
automatically scroll slowly to the right upon page load -- no
matter where the mouse is.
Any ideas?
Thank you!
-Karen
Here's the code I'm working with:
Attach Code
//Fill up these variables and your done
//To make it easier to edit, the mask and the movieclip
should stay on the _root
onClipEvent (load) {
//Total width of the whole movie stage
nMovieWidth = 950;
//Width of the movieclip to move (This)
//Don't forget to put the right width after you add more
thumbnails.
nClipWidth = 1895.3;
//_x value of the movieclip to move (Take the _root value)
//Put the same as nMaskX and make sure your MovieClip is at
this position
nClipX = 0;
//Max speed (FPS) of the scroll
nMaxSpeed = 8;
//These values are related to the mask of the movieclip
nMaskWidth = 950;
nMaskHeight = 225;
//_x value of the mask (Take the _root value)
nMaskX = 0;
//_y value of the mask (Take the _root value)
nMaskY = 25;
//Second _x value of the mask
nMaskXX = (nMaskX+nMaskWidth);
//Second _y value of the mask
nMaskYY = (nMaskY+nMaskHeight);
//nPixels determines the speed of the slider movement
function moveLeft(nPixels) {
this._x -= nPixels;
if (this._x>nMaskX) {
this._x = nMaskX;
function moveRight(nPixels) {
this._x += nPixels;
if (this._x<(nMaskWidth-nClipWidth+nClipX)) {
this._x = (nMaskWidth-nClipWidth+nClipX);
onClipEvent (enterFrame) {
//Move slider with speed dependent on mouse position inside
the Mask coordinates
if (_root._xmouse<(nMovieWidth/4) &&
_root._xmouse>nMaskX) {
if (_root._ymouse>nMaskY &&
_root._ymouse<nMaskYY) {
moveLeft(_root._xmouse*nMaxSpeed/(nMovieWidth/4)-nMaxSpeed);
} else {
if (_root._xmouse>(nMovieWidth/2) &&
_root._xmouse<nMaskXX) {
moveRight(nMaxSpeed-_root._xmouse*nMaxSpeed/(nMovieWidth/2));
