2 Replies Latest reply on Sep 7, 2012 1:57 PM by creditunion123
    Dialogue tick boxes un-hiding all fields, not just the ones where value has changed to true
    creditunion123
      I am hoping someone can help me make what I want to happen, happen if certain check boxes are ticked withing the dialogue box
      right now I can see on the console print that the tick box turns the value from false to true but the OK button is also un-hiding all my fields rather than just the ones where the value has turned to true. What am I missing here
      //Create a Dialogue box for staff to state how many of the account owners are in branch in order for the names to show in the signing section
      var Signors =
          result:"cancel",
          DoDialog: function(){return app.execDialog(this);},
          bChk2:false,
          bChk3:false,
          bChk4:false,
          bChk5:false,
          initialize: function(dialog)
              var dlgInit =
                      "Chk2": this.bChk2,
                      "Chk3": this.bChk3,
                      "Chk4": this.bChk4,
              dialog.load(dlgInit);
          commit: function(dialog)
              var oRslt = dialog.store();
              this.bChk2 = oRslt["Chk2"];
              this.bChk3 = oRslt["Chk3"];
              this.bChk4 = oRslt["Chk4"];
          description:
              elements:
                      type: "view",
                      elements:
                              type: "view",
                              char_height: 10,
                              elements:
                                      type: "static_text",
                                      item_id: "stat",
                                      name: "Who is here to sign:",
                                      char_width: 15,
                                      alignment: "align_fill",
                                      font: "dialog",
                                      type: "view",
                                      char_width: 8,
                                      char_height: 8,
                                      align_children: "align_top",
                                      elements:
                                              type: "view",
                                              char_width: 8,
                                              char_height: 8,
                                              elements:
                                                      type: "check_box",
                                                      item_id: "Chk2",
                                                      name: "Primary Applicant",
                                                      type: "check_box",
                                                      item_id: "Chk3",
                                                      type: "check_box",
                                                      item_id: "Chk4",
                              type: "ok_cancel",
      // did the value change when ticked - lets check
      Signors.bChk2 = false;
      Signors.bChk3 = false;
      Signors.bChk4 = false;
      if("ok" == Signors.DoDialog())
          if (Signors.bChk2 = true)
      getField("Signor1").hidden = false;
      getField("Staff1").hidden = false;
      getField("Date1").hidden = false;
      getField("Date2").hidden = false;
      if (Signors.bChk3 = true)
      getField("Signor2").hidden = false;
      getField("Staff2").hidden = false;
      getField("Date3").hidden = false;
      getField("Date4").hidden = false;
      if (Signors.bChk4 = true)
      getField("Signor3").hidden = false;
      getField("Staff3").hidden = false;
      getField("Date5").hidden = false;
      getField("Date6").hidden = false;
          console.println("Chk2:" + Signors.bChk2);
          console.println("Chk3:" + Signors.bChk3);
          console.println("Chk4:" + Signors.bChk4);
          console.println("Chk5:" + Signors.bChk5);
      //console.println shows if bChk.. is true or false
      //Yeah, confirmed values have changed, now show fields based on staff input
      //was primary applicant ticked
      doWhatIWant: function(results) {
      if (results [Signors.bChk2] = true)
      //was Associate 1 ticked
      if (results [Signors.bChk3] = true)
      //was Associate 2 ticked
        • 1. Re: Dialogue tick boxes un-hiding all fields, not just the ones where value has changed to true
          George_Johnson MVP & Adobe Community Professional
          You're missing some curly brackets, using the incorrect equality operator, and using the long deprecated field.hidden property. Try this:
          if ("ok" == Signors.DoDialog()) {
              if (Signors.bChk2) {
                  getField("Signor1").display = display.visible;
                  getField("Staff1").display = display.visible;
                  getField("Date1").display = display.visible;
                  getField("Date2").display = display.visible;
              if (Signors.bChk3) {
                  getField("Signor2").display = display.visible;
                  getField("Staff2").display = display.visible;
                  getField("Date3").display = display.visible;
                  getField("Date4").display = display.visible;
              if (Signors.bChk4) {
                  getField("Signor3").display = display.visible;
                  getField("Staff3").display = display.visible;
                  getField("Date5").display = display.visible;
                  getField("Date6").display = display.visible;
          I don't know if that will deal with all of the problems, but it's a good start.
          • 2. Re: Dialogue tick boxes un-hiding all fields, not just the ones where value has changed to true
            creditunion123 Level 1
            Just had to add a curly bracket at bottom of bChk3 and it worked perfectly. Thanks so much!!
