5 Replies Latest reply on Sep 8, 2012 12:00 PM by posmindset
    adobe bridge errors
    posmindset
      trying to view the .ffx presets in adobe bridge for after effects and when i select any of them the picture icon and the name pop up in the preview panel but they nothing else happens.
      none of them play: animations, text, or sound
      what is the problem? how do i fix?
        • 1. Re: adobe bridge errors
          Dave LaRonde Level 6
          Sorry, I can't make out your query agains the dark background.
          • 2. Re: adobe bridge errors
            Yeah, Dave is wearing goggles which is even recognizable in his avatar (the same is true for a lot of other people around here), so you should do us all a favor and forego fancy text styling with black on a dark-bluish grey. Anyway, since you didn't provide any system info nor what version you actually use we can only givce you the stock answer: Update Quicktime and configure it properly along with your graphics driver.
            Mylenium
            • 3. Re: adobe bridge errors
              posmindset Level 1
              trying to view the .ffx presets in adobe bridge cs6 for after effects and when i select any of them, the picture icon and the name pop up in the preview panel but the actual graphic/animation/sound do not show up and autom play ....and nothing happens.
              None of them play: animations, text, or sound
              what is the problem?  how do i fix it ?
              • 4. Re: adobe bridge errors
                As I said, all that stuff requires a working Quicktime install, as that's what is being used to do the previews. Beyond that we really can't advise because you are not giving us enough information.
                Mylenium
                • 5. Re: adobe bridge errors
                  posmindset Level 1
                  Mylenium,
                  There's no need for the negative approach.  The "fancy styling" you refer to is from copying my question from another post i made.  It pasted that way and for some reason the dark background displayed with it.  I tried, but could not remove it.
                  As I could still read the sentences, I made the assumption that others would be able to as well.....my mistake.
                  My system information is below.
                  windows 7
                  toshiba satellite a665 laptop intel i3 cpu M370 2.40 ghz
                  8gb ram 64 bit
                  Intel hd graphics card
                  500gb hard drive with 100gb free
                  i'm using adobe creative cloud cs6
                  I have uninstall and reinstalled quicktime player and adjusted the settings and now the affects show up when i click on them, but not all of them will play.  Some will play and some won't.  When i select one, the splash image will appear the and scroll bar shows it's playing but the animation doesn't happen.
                  I have noticed that if i undock the bridge program from the screen and move it a bit, then the animations will show as they are playing.
                  A few will play but most won't.
                  thanks for any help
