8 Replies Latest reply on Sep 15, 2012 8:45 AM by beh_gras_beh
    Rename XML tags
    beh_gras_beh
      Dear People,
      Is there a way to find and replace all XML items.
      find xmlTags.item("tag1") replace to xmlTags.item("tag2") ?
      Greetings
        • 1. Re: Rename XML tags
          Fred Goldman Level 3
          var myElements = myElement.evaluateXPathExpression("//tag1");
          for(var x = myElements.length -1;x>=0;x--)
          myElements[x].markupTag = myDoc.xmlTags.item("tag2");
          • 2. Re: Rename XML tags
            beh_gras_beh Level 1
            Dear Fred,
            Thanks for the help.
            I know it is a stupid question but why is the script giving me a error myElement is undifined.
            Because of the myElement.evaluateXPathExpression?
            But maybe I thought it was the path? ("//Workbook/tag1")?
            What am I doing wrong?
            P.s. Forgot to mention i'm on CS5 (MAC).
            • 3. Re: Rename XML tags
              All the variables that start with "my" are my own variables. You should
              replace those with a whatever variable you are working with.
              For example:
              var myElement = app.activeDocument.xmlElements[0];
              • 4. Re: Rename XML tags
                Still learning, but am I going the right way?
                var myElement = myDoc.xmlElements.item(0);
                • 5. Re: Rename XML tags
                  Looks good!
                  • 6. Re: Rename XML tags
                    Edit.
                    Have it!!!!
                    myElements[x].markupTag.name =("tag2");
                    Thank you very much for the help!
                    As you can see Im still trying to understand how Javascript works.
                    Again thanks.
                    • 7. Re: Rename XML tags
                      Kasyan Servetsky Level 5
                      I think it makes no sense to loop through all the xml-elements to change the name of a tag. As in the UI, you have to do this only once:
                      if (myElements.length > 0) myElements[0].markupTag.name = "tag2" ;
                      Or even simpler:
                      var myTag = myDoc.xmlTags.itemByName("tag1");
                      myTag.name = "tag2";
                      On the other hand, if you want to apply a different tag to an xml-element, you can do it like so:
                      for (var x = myElements.length -1;x>=0;x--)
                                      myElements[x].markupTag = myDoc.xmlTags.itemByName("tag2") ;
                      • 8. Re: Rename XML tags
                        Thanks!
                        That is very usefull!
                        Greetings!
