2 Replies Latest reply on Aug 29, 2006 6:57 PM by BugMan1400
    more masking questions
    BugMan1400
      Is there a way to cut through 2 layers when masking? I am trying to fit a smaller oval into a larger oval, do a Fill-in between the two borders, then lay the product over a bitmap. Like the following:
      http://www.parkwalkcondos.com/
        • 1. Re: more masking questions
          llamaparsnip Level 1
          Draw your ellipse, copy and paste it (ctr-c, ctrl-v) then scale the copy up by 110%. Give it the colour you want . Cut your photo (ctr-x), then select the smaller ellipse and click Edit > Paste Inside. If you want an inner shadow, as in your example, click on the ellipse (the vector mask one) in the layers palette and add an inner shadow.
          • 2. Re: more masking questions
            BugMan1400 Level 1
            quote:
            That worked GREAT!!! Mucho Thanks for the info.
