1. Re: How to install Adobe PDF toolbar in Internet Explorer
Anoop9178 Sep 11, 2012 4:38 AM (in response to utrcbill1)If you install Acrobat 10 then it will automatically configure the PDFMaker toolbar in I.E. You can try repairing the software.
Open Acrobat -> Go to Help menu -> Repair Acrobat Installation.
Solution #2
Select "Enable third-party browser extensions" in Internet Explorer Properties.
1. Start Internet Explorer.
2. Select Tools > Internet Options and click the Advanced tab.
3. Select "Enable third-party browser extensions (requires restart)" and click OK.
4. Close all Internet Explorer windows.
5. Restart Internet Explorer.
If still doesn't work then let me know what the version of I.E and Acrobat you are using.
2. Re: How to install Adobe PDF toolbar in Internet Explorer
utrcbill1 Sep 15, 2012 1:24 PM (in response to Anoop9178)Thank you very much. I will try this later this afternoon.
[ edited by forum host - email signature removed ]
3. Re: How to install Adobe PDF toolbar in Internet Explorer
Sabian Zildjian Sep 13, 2012 10:01 AM (in response to Anoop9178)Just a addendumn to what Annop9178 said. The process he documents will only work with the 32-bit version of Internet Explorer. The Adobe Acrobat and Reader ActiveX plug-in for Internet Explorer is not yet compatible with Internet Explorer 64-bit.
4. Re: How to install Adobe PDF toolbar in Internet Explorer
utrcbill1 Sep 15, 2012 1:24 PM (in response to Sabian Zildjian)Everything is now working very well. Thank you so much for your help.
5. Re: How to install Adobe PDF toolbar in Internet Explorer
Bill@VT Sep 16, 2012 5:15 AM (in response to Sabian Zildjian)I thought this was fixed for the latest version of AAX.
6. Re: How to install Adobe PDF toolbar in Internet Explorer
le_flyer Jul 10, 2013 11:50 AM (in response to Anoop9178)I have also lost the PDF Converter. It was running great the other day, but as of today, it is gone.
I am running Windows 7, ie9, with "Enable third-party broweser extensions " enabled. I have also did the repair on adobe X. Still no luck in getting the Adobe Toolbar installed.
I have looked at the add-ons and the tool bar is not present in IE9.
Do I need to re-install Adobe X.
Just a note, I accidentially had IE10 to install on my Windows 7 and 8 PCs. Had to remove it as IE 10 does not work for all my applications. Would that have an bearing on this problems?
I would appreciate hearing from you
7. Re: How to install Adobe PDF toolbar in Internet Explorer
Test Screen Name Jul 10, 2013 11:53 AM (in response to le_flyer)Always try a REPAIR before an uninstall/reinstall.
