14 Replies Latest reply on Sep 10, 2012 8:24 AM by pauland
    Help with calculation
    jfb00 Level 3
      I have a  calcualtion with result negative infinity (in.fin.ity.00).
      I try to use isNaN(calculation) for validation but is not working.
      tempCal = myCaculation
      if (isNaN(tempCal)){
           finalCal = 0;
      }else{
           finalCal = tempCal;
      How can I validate this result?
      Thanks in advance.
      Best,
        • 1. Re: Help with calculation
          pauland Level 4
          wrap the calculation in try.. catch.
          • 2. Re: Help with calculation
            jfb00 Level 3
            Thanks for you reply and help.
            How? like this...
            try
                 myCalculation
            catch (error:*)
                 finalCal = 0;
            finally
                 finalCal = myCalculation;
            • 3. Re: Help with calculation
              pauland Level 4
              Yes, give it a go. Strictly speaking, finally is not required.
              • 4. Re: Help with calculation
                pauland Level 4
                Oops, your code is wrong.
                try
                catch (error:*)
                     finalCal = 0;
                • 5. Re: Help with calculation
                  jfb00 Level 3
                  The catch doesn't get any error, any other idea?
                  import mx.controls.Alert;
                              private function init():void{
                                  var finalCal:Number;
                                  var myCal:Number= 24/0;
                                  try
                                      myCal;
                                  catch (error:*)
                                      finalCal = 0;
                                  finally
                                      finalCal = myCal;
                                  Alert.show(finalCal.toString());
                  • 6. Re: Help with calculation
                    jfb00 Level 3
                    Try without finally, the same issue, catch doesn't get any error:
                                    try
                                        finalCal = myCal;
                                    catch (error:*)
                                        finalCal = 0;
                    • 7. Re: Help with calculation
                      pauland Level 4
                      How about ..
                                      try
                                          finalCal = 24/0;
                                      catch (error:*)
                                          finalCal = 0;
                      • 8. Re: Help with calculation
                        pauland Level 4
                        It's clever enough to spot the div by zero, but here's a clue.
                        trace(finalCal.toString()+" "+ (finalCal==NaN));
                        I get "Infinity false"
                        • 9. Re: Help with calculation
                          jfb00 Level 3
                          Yes, that is my issue.
                          How can I validate that infinity?  (my original question)
                          Thanks for trying...
                          • 10. Re: Help with calculation
                            pauland Level 4
                            I've already shown you, but here you go:
                                            try
                                                finalCal = 24/0;
                                            catch (error:*)
                                                finalCal = 0;
                                           if ( finalCal==NaN){
                                                finalCal = 0;
                            • 11. Re: Help with calculation
                              NMed
                              Refer to the APIs for function clarification:  http://help.adobe.com/en_US/FlashPlatform/reference/actionscript/3/package.html#isNaN()
                              A non-zero number when divided by 0 is inputted into isNaN the return is false (even though you would expect it to be true since the result traces as 'infinity').
                              The original question is a little vague, but from the way I understand it, there's no need for try-catch.  This should work:
                              if(isFinite(YOUR_NUMBER) && !isNaN(YOUR_NUMBER))
                                   //if YOUR_NUMBER is finite and it is NOT NaN... you're here.
                              else
                                   //else, YOUR_NUMBER is either infinite or it is NaN...
                              • 12. Re: Help with calculation
                                jfb00 Level 3
                                I got this
                                1098: Illogical comparison with NaN. This statement always evaluates to false.
                                • 13. Re: Help with calculation
                                  jfb00 Level 3
                                  You got the solution NMed. First time i see isFinite.
                                  Thanks !
                                  • 14. Re: Help with calculation
                                    pauland Level 4
                                    Good job NMed!
