1 Reply Latest reply on Feb 22, 2008 2:41 AM by ojkoorde
    eclipse +flex 3 plugin crashes when trying to see mxml file in design mode
    ojkoorde
      I have strange problem I've been struggling with for 3 days.
      I have eclipse-jee-europa-fall2-win32(eclipse europa 3.3.1.1) + adobe flex 3 eclipse plugin.
      My workspace consists of several projects + one library.
      There is not problem when trying to edit any mxml file when my library is not imported yet. Once I import it to my workspace I cannot see any mxml file in design mode since it crashes with the following msg in log:
      Did anyone have similar problem and maybe knows the solutiuon? I've reinstalled/redownoaded eclipse, flex plugin, flash players and so on. What's more it happens only on my machine - same project on different one works without crushing.
      !ENTRY org.eclipse.osgi 2 0 2008-02-22 09:13:18.046
      !MESSAGE While loading class "org.eclipse.mylyn.tasks.ui.TasksUiPlugin", thread "Thread[main,6,main]" timed out waiting (5000ms) for thread "Thread[Worker-0,5,main]" to finish starting bundle "update@plugins/org.eclipse.mylyn.tasks.ui_2.1.0.v20070927-0900.jar [313]". To avoid deadlock, thread "Thread[main,6,main]" is proceeding but "org.eclipse.mylyn.tasks.ui.TasksUiPlugin" may not be fully initialized.
      !STACK 0
      org.osgi.framework.BundleException: State change in progress for bundle "update@plugins/org.eclipse.mylyn.tasks.ui_2.1.0.v20070927-0900.jar" by thread "Worker-0".
      at org.eclipse.osgi.framework.internal.core.AbstractBundle.beginStateChange(AbstractBundle.j ava:1141)
      at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:258)
      at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:400)
      at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLa zyStarter.java:111)
      at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java :417)
      at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoade r.java:189)
      at org.eclipse.osgi.framework.internal.core.BundleLoader.findLocalClass(BundleLoader.java:34 0)
      at org.eclipse.osgi.framework.internal.core.SingleSourcePackage.loadClass(SingleSourcePackag e.java:37)
      at org.eclipse.osgi.framework.internal.core.BundleLoader.findClassInternal(BundleLoader.java :405)
      at org.eclipse.osgi.framework.internal.core.BundleLoader.findClass(BundleLoader.java:369)
      at org.eclipse.osgi.framework.internal.core.BundleLoader.findClass(BundleLoader.java:357)
      at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.jav a:83)
      at java.lang.ClassLoader.loadClass(Unknown Source)
      at java.lang.ClassLoader.loadClassInternal(Unknown Source)
      at org.eclipse.mylyn.context.ui.ContextUiPlugin$5.run(ContextUiPlugin.java:258)
      at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
      at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:123)
      at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3659)
      at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3296)
      at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2389)
      at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
      at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2219)
      at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
      at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:289)
      at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:461)
      at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
      at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:106)
      at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:169)
      at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:106)
      at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:76)
      at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:363)
      at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:176)
      at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
      at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
      at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
      at java.lang.reflect.Method.invoke(Unknown Source)
      at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:508)
      at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
      at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
      at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
      Caused by: org.eclipse.osgi.framework.internal.core.AbstractBundle$BundleStatusException
      ... 40 more
      Root exception:
      !ENTRY org.eclipse.help 4 0 2008-02-22 09:18:14.375
      !MESSAGE Required attribute "label" missing from "topic" element in "/com.adobe.flexbuilder.help/tocAPI.xml" (skipping element)
        • 1. Re: eclipse +flex 3 plugin crashes when trying to see mxml file in design mode
          ojkoorde Level 1
          I've found solution by myself so I'll present it here. Maybe someone will need it.
          The problem of such behaviour was that Flex plugin always (at least on my pc) wants to ustart eclipse using its own JRE from here C:\Program Files\Adobe\Flex Builder 3 Plug-in\jre (default dir). This environment is Java 5. When you go to eclipse>window>preferences>Java>Installed JREs and you delete default Flex JRE, add new to point to for example C:\Program Files\Java\jre1.6.0_04 eclipse still uses JRE from C:\Program Files\Adobe\Flex Builder 3 Plug-in\jre. Do not know why Flex/eclipse does that but if you simply overwrite C:\Program Files\Adobe\Flex Builder 3 Plug-in\jre files with newer JRE from C:\Program Files\Java\jre1.6.0_04 all works perfectly.
          Hope it helps somebody ;-)
          thanks Artur
