1 Reply Latest reply on Sep 10, 2012 2:55 PM by MrTIFF
    Does anyone know a script that copies transformations of a frame?
    goo27 Level 1
      I'd like a script where all the frames selected on a spread can copy an original frame's transformations. So, for example:
      I have 3-5 photo frames at different sizes and spaced unequally. I set one frame to be a perfect square with a photo filled proportionally. Set the stroke to 1 at registration black. Now, I'd like the other frames to be exactly the same (but holding different photos) and spaced at 1 cm vertically and horizontally from each other. Is this possible? If so, how do I go about either creating the script or better still, buying it?
      "Transform sequence again individually" command just doesn't work for me and is too time consuming.
      Best and thanks for the help.
