18 Replies Latest reply on Oct 27, 2017 2:52 PM by musekic
    Scripting Specific Link Replacement
    UpdateRequired
      Our company is undergoing a name/logo change and we have around 1000-1500 indesign documents that need to have logo links replaced/re-linked.
      I need some help creating a script, preferably using javascript, that will allow me to relink  around 10 different logo files to completely different paths with completely different file names.   All of the files are on a windows based server, and all of our indesign users are windows cs5.0 based as well.  I would like the script to loop through a set of specific logo links and have it replace any and all instances of old logos with the new logos.
      Example
      K:\poor\directory\structure\sadface\RedCoLogo_White.eps   becomes   L:\CompanyLogos\BlueIncLogo_W.eps
      K:\poor\directory\structure\sadface\RedCoLogo_Black.eps   becomes   L:\CompanyLogos\BlueIncLogo_B.eps
      K:\poor\directory\structure\sadface\RedCoLogo_Red.eps   becomes   L:\CompanyLogos\BlueIncLogo_R.eps
      K:\poor\directory\structure\sadface\RedCoLogo_Green.eps   becomes   L:\CompanyLogos\BlueIncLogo_G.eps
      I have already tried some premade scripts that use dialogue boxes to input the old path and new path, but I need the script to run without user interaction so it can batch run it using another script I found that will open the indesign files in a given directory, run a script, save and close.
      I do not know javascript very well, but I am fimiliar with how it works and its syntax/etc; I have already customized a handfull of FindChangeByList scripts to use different txt files and loop through a specific number of active indesign files.
      Any help would be greatly appreciated.
        • 1. Re: Scripting Specific Link Replacement
          MrTIFF Level 3
          There are several scripts at:
          http://www.kasyan.ho.com.ua/my_scripts.html
          which may be applicable to your situation.
          (Let me know privately if you want help in adapting one of them.)
          • 2. Re: Scripting Specific Link Replacement
            UpdateRequired Level 1
            I have tried/tinkered with all of the sctipts on kasyan's page already.  The one that closest matches my needs is http://www.kasyan.ho.com.ua/restore_paths_of_links.html since it works with absolute file paths including the file name.  However it requires user interaction and will only do one file at a time (no different than just relinking via the links pallete).
            I can comment out the dialogue box and confirmation screens easily to run unattended, but since the dialogue box is used to write the paths to a magic file on the desktop, I cannot figure out how to hard code the old/new path(s) into the script.
            • 3. Re: Scripting Specific Link Replacement
              -hans- Level 4
              minor error handling. just basically tested. You may try it.
              #target InDesign
              app.scriptPreferences.userInteractionLevel = UserInteractionLevels.NEVER_INTERACT
              app.activate();
              var myFolder = 'L:/CompanyLogos/';
              var toSearch = ['RedCoLogo_White.eps', 'RedCoLogo_Black.eps', 'RedCoLogo_Red.eps', 'RedCoLogo_Green.eps'];
              var toRelink = ['BlueIncLogo_W.eps', 'BlueIncLogo_B.eps', 'BlueIncLogo_R.eps', 'BlueIncLogo_G.eps'];
              var inddFiles = Folder.selectDialog ('Please choose folder with *.indd-files').getFiles('*.indd');
              var l = inddFiles.length;
              while(l--){
                  try{
              app.open(inddFiles[l]);
              var theDoc = app.activeDocument;
              var allLinkNames =theDoc.links.everyItem().name;
              for(var i = 0; i < toSearch.length; i++)
              var myName = toSearch[i];
              for(var s = 0; s < allLinkNames.length; s++)
              var linkName = allLinkNames[s];
              if    (linkName === myName){
              var newFile = File(myFolder + toRelink[i]);
              theDoc.links[s].relink(newFile);
                  theDoc.save();
              theDoc.close();
              }catch (e){
                  app.scriptPreferences.userInteractionLevel = UserInteractionLevels.INTERACT_WITH_ALL;
                  displayDialog(e);
                  app.scriptPreferences.userInteractionLevel = UserInteractionLevels.NEVER_INTERACT;
              function displayDialog(aString){
              var infoWindow = new Window("palette");
              infoWindow.add("statictext", undefined, aString);
              infoWindow.show();
              $.sleep(1000);
              infoWindow.close();
              Hans-Gerd Claßen
              • 4. Re: Scripting Specific Link Replacement
                Simply amazing!  I edited it to use my specific paths and file names and it works like a dream; it's pretty quick too.
                How difficult would it be to add in commands for "Fit Content Proportionally" and "Center Content" that only alter the frames of the re-linked eps files?
                • 5. Re: Scripting Specific Link Replacement
                  -hans- Level 4
                  Hallo UpdateRequired,
                  fine that it works
                  Not difficult at all.
                  Hans-Gerd Claßen
                  • 6. Re: Scripting Specific Link Replacement
                    Haha, that might be easy for you to say; I am not nearly as experienced with scripting as you are.
                    The closest commands I have found in searching so far for fit content to frame and centering are these:
                    app.activeDocument.rectangles.everyItem().fit(FitOptions.fillProportionally);
                    app.activeDocument.rectangles.everyItem().fit(FitOptions.centerContent);
                    However, I'm not sure how to add them into the script you created, or how to have it only affect the logo files that are being relinked.  I would guess that I need to create a variable and have it use the link names I define to apply fitting to; probably by replacing .everyItem().  I just don't know quite how to accomplish this.
                    • 7. Re: Scripting Specific Link Replacement
                      @UpdateRequired – just a hint:
                      find out what the "parent" object of a specific link is.
                      And the "parent" of that "parent"…
                      app.activeDocument.links[0].parent;
                      app.activeDocument.links[0].parent.parent;
                      Uwe
                      • 8. Re: Scripting Specific Link Replacement
                        -hans- Level 4
                        Hello UpdateRequired,
                        Uwe gave you the right kick, so you may have the ability to solve it.
                        Here's the part that's important for your needs:
                        //get parent and apply the fit commands
                        Have to say it's all well-meant just trying to follow the dos and don't
                        Have a sunny weekend
                        Hans-Gerd Claßen
                        • 9. Re: Scripting Specific Link Replacement
                          Harbs. Level 6
                          You can feel free to give the full answer. All I meant there was that the person asking shouldn't expect to get the full code written for them...
                          • 10. Re: Scripting Specific Link Replacement
                            -hans- Level 4
                            I've added the the fit-options ....
                            #target InDesign
                            app.activate();
                             if (l === 0){displayDialog('The selcted folder doesn\'t contain ID-Files'); exit()};
                            while(l--){
                                try{
                            with(theDoc.links[s]){
                                relink(newFile);
                            parent.fit(FitOptions.fillProportionally);
                            parent.fit(FitOptions.centerContent);
                                    theDoc.save();
                            theDoc.close();
                            }catch (e){
                                displayDialog(e);
                            infoWindow.show();
                            $.sleep(2000);
                            infoWindow.close();
                            Hope it'll work
                            • 11. Re: Scripting Specific Link Replacement
                              Thank you all so much.  This is more help than I expected to get.  I just had to modify FitOptions.fillProportionally to be FitOptions.proportionally to get the desired outcome; the results are smashing!  I also have a slightly better grasp on js because of this undertaking.
                              I'll toast my next beer to Hans .
                              • 12. Re: Scripting Specific Link Replacement
                                mstfhyt
                                Hi;
                                I tried the code. But the code says it can not find the logo file. But on the desktop with the same name and logos in a file that I created. What I missed?
                                • 13. Re: Scripting Specific Link Replacement
                                  ArgoChristian
                                  -hans-
                                  I  know it's years later. But your reply script saved me (and others at my work) countless hours worth of work. I modified it to be applicable to my path and image names. Boom! Far less work for me. Thank you, thank you, thank you! You're awesome!
                                  • 14. Re: Scripting Specific Link Replacement
                                    idjev Level 1
                                    code  I modified it to be applicable to my path and image names.
                                    But the code says it can not find the logo file. help please
                                    indesign CC 2017 win / mac os
                                    • 15. Re: Scripting Specific Link Replacement
                                      We need more information to answer this.
                                      Are there any special characters in your file names?
                                      Is the folder of the logo stored on a network volume connected?
                                      Is the volume connected in the moment you run that script?
                                      Also: Maybe something's wrong with your folder path definition?
                                      Place the logo from the path on a page and try to find the folder string.
                                      Select the graphic frame holding the logo and run the following script snippet:
                                      var graphic = app.selection[0].graphics[0];
                                      var file = File(graphic.itemLink.filePath);
                                      $.writeln(file.parent);
                                      The file's parent is the folder where the placed logo is stored.
                                      And the $.writeln() is writing its path to the JavaScript Console of the ESTK.
                                      Test this snippet with your Mac and your Windows version of InDesign.
                                      There might be a difference in the path discription.
                                      Regards,
                                      Uwe
                                      • 16. Re: Scripting Specific Link Replacement
                                        Note:
                                        in the meanwhile idjev sent me a PM with a link to his implementation of the script by Hans.
                                        Hi idjev,
                                        note that paths used with ExtendScript—also on Windows—should not use backslashes, but slashes to get the right folder:
                                        Do not do a backslash:
                                        var myFolder = 'C:\myFolderName';
                                        Instead do a slash:
                                        var myFolder = 'C:/myFolderName';
                                        ( Obviously you did not follow my advice in my last post and test the path on a placed and selected graphic. )
                                        Regards,
                                        Uwe
                                        • 17. Re: Scripting Specific Link Replacement
                                          idjev Level 1
                                          Laubender  ,
                                          God bless you ... thank you so much
                                          • 18. Re: Scripting Specific Link Replacement
                                            musekic
                                            Many Thanks Hans!
