1. Re: Difference Between native Android and ANE
esdebon Sep 11, 2012 3:07 PM (in response to Apocalyptic0n3)AIR is like the Java Virtual Machine, is a program runing on your device natively, but an app Runing on AIR is no a native App.
2. Re: Difference Between native Android and ANE
Apocalyptic0n3 Sep 11, 2012 3:53 PM (in response to esdebon)That is what I assumed. The resulting app is, in Android's case, a single Activity that runs as a window to the AIR app. What I'd like to figure out is why modifying that Activity using native Java is different than using a native app. I'm not modifying the AIR app itself, just the activity the AIR app is using.
3. Re: Difference Between native Android and ANE
BigBobsky Oct 2, 2012 1:47 AM (in response to Apocalyptic0n3)I've got exactly the same problem : did you found a solution ?
If I observe the view hierarchy created after adding a VideoView, I get :
android.widget.FrameLayout
|-android.widget.FrameLayout (a different one)
|-com.adobe.AIRWindowSurfaceView
|-android.widget.VideoView
I tried a lot of things : invalidating the views on Java side, refreshing on Actionscript side, bringing the VideoView to front in Java code ... But nothing works : when the VideoView is starting, the sound begins but the VideoView seems to be behind the AirWidnowSurfaceView until I perform a standby.
I've tried to place the VideoView just above the root FrameLayout, but it changed nothing.
According to his name, I think AIRWindowSurfaceView is derivating from SurfaceView so I can't add any child.
More ideas ?
Regards
4. Re: Difference Between native Android and ANE
Apocalyptic0n3 Oct 2, 2012 3:53 AM (in response to BigBobsky)I spent three days trying to fix that very issue. Ended up having to call it quits and move on to another idea to fix Android video. That's about all I can offer you. Sorry.
5. Re: Difference Between native Android and ANE
BigBobsky Oct 4, 2012 2:22 AM (in response to Apocalyptic0n3)I finally found the right solution this morning and my native VideoView is shown as soon as the ANE call is returning, and the VideoView can be managed as wanted, and now I can play H264 mp4 and HLS more easily.
6. Re: Difference Between native Android and ANE
Apocalyptic0n3 Oct 4, 2012 5:06 AM (in response to BigBobsky)How were you able to do it?
7. Re: Difference Between native Android and ANE
BigBobsky Oct 4, 2012 5:26 AM (in response to Apocalyptic0n3)I created a native implementation function in Java to create a VideoView. In this function I get the first child of the android.R.id.content view :
FrameLayout root = (FrameLayout)act.getWindow().getDecorView().findViewById(android.R.id.content); ret = (FrameLayout)root.getChildAt(0); It should be a FrameLayout containing a com.adobe.AIRWindowSurfaceView.
I call setZOrderOnTop(true) on this VideoView, then I add my VideoView to the FrameLayout.
I set FrameLayout.LayoutParameters to define the size and position of the video.
It's the first implementation I described in my initial post and which didn't not work. I just added the setZOrderOnTop(true) in place of my initial bringToFront().
8. Re: Difference Between native Android and ANE
heartgoon Jun 6, 2013 7:58 PM (in response to BigBobsky)can you show us your code?
9. Re: Difference Between native Android and ANE
heartgoon Jun 6, 2013 8:03 PM (in response to Apocalyptic0n3)i want to ask u another question,if u jump from the flex to ane,would it be slow?
if u return from the ane to flex,and than go back to ane,would the activity recreate or keep?
