• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
1
How to change the color picker/color space view?
New Here ,
Sep 11, 2012 Sep 11, 2012
I wanted to change the color picker/color space view to what it looks like in the other Adobe programs. I have gotten used to using the color picker from the other programs and I have had problems with the look and function of this color view.
In InDesign the color picker looks like this:
And the Photoshop/Illustrator/etc. looks like this:
I've tried changing the "Convert To Profile..." and the Transparency Blend Space, but neither have done anything to what I want to be done.
Is there some way to change this in InDesign?
Note: I want to change the looks of the gradient-like area if that isn't obvious.
TOPICS
How to
Views
65.7K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Sep 30, 2016 Sep 30, 2016
Rob,
You are wrong. If you're on a Mac with appropriate hardware and you're using the current version of InDesign, you have Animated Zoom. See below:
I wrote about it here:
GPU Support and Animated Zoom Arrives (for the Mac ...
Votes
Translate
Translate
Community Expert ,
You can't change the color picker in ID.
Votes
Translate
Translate
Report
Report
Engaged ,
Dec 02, 2012 Dec 02, 2012
Why is Adobe products so inconsistent?  Why would color picker be showing RGB space when working in CMYK color space even at CS6!
Votes
Translate
Translate
Report
Report
Community Expert ,
InDesign doesn't have a document color space like Illustrator and Photoshop—a document can have a mix of either CMYK, RGB, or Lab objects, and the 3 color pickers (the Color Picker, Color, and Swatches panels) are limited to those spaces. There's no Grayscale or HSB, and it's the missing HSB's H view that's intuitive for picking color and would be nice to have—but I'm guessing it's not as easy as it seems to engineer when there's no document color space.
Votes
Translate
Translate
Report
Report
New Here ,
May 26, 2013 May 26, 2013
I was wanting to do the same change as you, until I saw your two images.
Within the InDesign image you've selected a dark blue colour (R:16, G:49, B:152)  AND you've got the (R)ed channel selected.
Within the Photoshop image you've selected a white colour(R:255, G:255, B:255)  AND you've got the (H)ue channel selected.
In Photoshop I can recreate both of your images by having the same settings for RGB/CMYK and selecting the same channel item as you have in those images.
That's all.
There is no difference between the two colour selection dialogs except where the HSB, RGB, CMYK and LAB are placed.
Votes
Translate
Translate
Report
Report
New Here ,
Aug 24, 2016 Aug 24, 2016
Adobe you should give an option to change the color picker!! I hate the one that comes standard in InDesign. I usually have to edit my in colors in illustrator and then copy and past the hex code in InDesign. It is such a pain!!!
Votes
Translate
Translate
Report
Report
Here's a link you can use to request it as a feature : Feature Request/Bug Report Form
Regards,
Om
Votes
Translate
Translate
Report
Report
Community Beginner ,
You're wasting your time. This has been a phenomenal nuisance for designers every since Id was released. I just spoke with a csr at Adobe and she said that they will not change it, or at least give the option for the much easier to use color picker that Ai & Ps use, as that's the way the program was designed. Their logic doesn't make sense, but that's just how it is. I'm very surprised that they wouldn't listen to the people who use it and i don't know anyone who prefers this picker. So, i guess i have to just keep using the color picker in Ai and copying the cmyk coordinates into the Id color picker....unless there's a better option?
Another thing is that i can't seem to use the quick zoom feature that Ai & Ps use (command + space). It's like Id was designed by a separate company than its other design apps.
Votes
Translate
Translate
Report
Report
Community Expert ,
InTools has a free hex script, that will pick up Photoshop's foreground color. It still works for me in CC2014
Hexadecimal Swatches in InDesign | in-tools.com
http://in-tools.com/downloads/indesign/scripts/CreateHexSwatch.zip
I think there is a color management/engineering problem that stops them from adding HSB to InDesign. InDesign allows multiple color spaces in a single document, while AI and PS have a single document color mode, so there's no ambiguity about how the chosen color will get converted from the HSB picker interface (there's no document HSB color mode or space in any of the Adobe apps). In Photoshop when you pick a color with any of the interfaces it gets converted into the document's color space, that's not an easy option with InDesign because there are 4 possible color spaces for the swatch or color fill when you pick. See #11 here:
Re: HSB color picker
Votes
Translate
Translate
Report
Report
Thanks a lot Rob, I'll definitely install this. Interesting about the colour space. i would have thought that AI & PS also have options to have the document in RGB or CMYK that it would be able to adapt to the platform's colour space.
Also, strange that the quick zoom is working for you. I'm on the newest OS and CC so i'll check the settings.
Cheers.
Votes
Translate
Translate
Report
Report
Community Expert ,
AI and PS force you to choose a document color space, but you can't mix color spaces as you can with ID. You can pick an RGB (or HSB) color, but if the document mode is CMYK, the chosen color gets converted to CMYK (and brought into gamut) when you apply it the the document—there's no need to make a choice while you are in the picker, it's understood what will happen to the color.
That's not the case with InDesign, and it is a powerful color management feature for page layouts, where being locked into a single color mode could create problems. A page can have a mix of RGB or CMYK images with different assigned profiles along with fills and strokes that can also be RGB, Lab, CMYK, or spot.
With the current ID Color Picker the mode of the fill or swatch you get depends on where your cursor is. In Photoshop the cursor position doesn't matter because the document's color mode determines the applied color space. So if ID adds HSB to the picker, there would have to be a way to tell the color picker what color mode you want since your cursor would be in the HSB field and there's no HSB color mode.
Votes
Translate
Translate
Report
Report
Community Expert ,
It works for me. Are you sure the OS or a custom key command isn't interfering with the default?
OSX uses Command-Space for Spotlight:
Votes
Translate
Translate
Report
Report
just checked and spotlight isn't the issue. if i use command/space and the mouse to zoom in or out, it only zooms into that area that's selected opposed to smoothly zooming in and out when i move the mouse right or left.
Votes
Translate
Translate
Report
Report
Community Expert ,
I misunderstood you, ID doesn't have an animated zoom.
Votes
Translate
Translate
Report
Report
Yes, animated zoom. That's a shame, it's a brilliant feature. ID is definitely a bit of an anomaly in the suite. Thanks for your help Rob.
Peace.
Votes
Translate
Translate
Report
Report
Community Expert ,
Rob,
Votes
Translate
Translate
Report
Report
Community Expert ,
Thanks. I should have checked more carefully, I'm still using 2014 on my production machine
Votes
Translate
Translate
Report
Report
Jul 05, 2018 Jul 05, 2018
No, you should just change it like you're supposed to do!
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
This old thread is devolving into unrelated topics. I'm locking it.
Votes
Translate
Translate
Report
Report
Feb 01, 2017 Feb 01, 2017
Had the same frustration so I googled "online rgb color picker" and the first result was Color Picker - ColorPicker.com
I haven't checked to see if it's color representation is perfectly accurate, but it is less resource heavy and easier than switching applications.
Helps me, hope it can help somebody else!
Votes
Translate
Translate
Report
Report
