2 Replies Latest reply on Sep 11, 2012 5:15 AM by moeAUT
    InDesign Glyphs Problem.
    moeAUT
      Hey.
      I have a little question.
      I want to change the default dash of one of my fonts in InDesign. So if I use the normal key "-" the dash is pretty long and I have to go to the glyphs-menu to make it shorter. Is it possible to change the short one to a default glyph in this font?
      Thank you.
      EDIT: The long dash only appears in the font "HelveticaNew LT 57 Cn" - in every other font, the dash has normal length.
        • 1. Re: InDesign Glyphs Problem.
          Eugene Tyson Adobe Community Professional & MVP
          You could set up a GREP Style, within your paragraph style.
          look for
          then create a new character style and change the Horizontal scaling to the desired amount.
          Any time you type the - the GREP style will kick in and the Horizontal scaling will apply to the -.
          But be warned, copying this text to another document may cause the dash to resize to normal.
          If you want to edit the glyph itself you'd have to use a font editor.
          • 2. Re: InDesign Glyphs Problem.
            moeAUT Level 1
            Ok, thanks for that.
            But in the glyph library for this font, there is a shorter dash - can I somehow make the short dash to my default dash?
            Best regards.
