1. Re: Editing HTML file leaves temporary files lying about the place
Miguel-F Sep 11, 2012 5:36 AM (in response to Adam Cameron.)I have noticed those files as well, however my CFB seems to delete them after I shut down CFB (not when I close the file). I am running CFB 2.0.0, Build 278082. Are your temp files still lingering around even after shutting down CFB?
I agree with you, it definitely needs to clean up after itself. I have also noticed that those temp files are created just by opening a HTML file, not only after editing one.
2. Re: Editing HTML file leaves temporary files lying about the place
Adam Cameron. Sep 11, 2012 6:03 AM (in response to Miguel-F)Are your temp files still lingering around even after shutting down CFB?
Actually now that I doa quick test, they are not. However I wonder if this is erratic because I do find the damned things accumulating. And if they were always cleaned up upon close, they'd not accumulate.
Curious.
Still: they should just not be there in the first place. They don't appear for any other file type that I am aware of.
Adam
3. Re: Editing HTML file leaves temporary files lying about the place
Miguel-F Sep 11, 2012 6:12 AM (in response to Adam Cameron.)Curious.
Agreed!
Come to think of it, I had another issue with CFB leaving bits around a while back. Ahhh, now I can't remember exactly what the issue was. I remember it had to do with mapping a networked drive. When I would map a particular drive letter, say 'W', then start CFB it would create an entire folder hierarchy on there seemingly from a different server. I know this because we have two different CF environments here; some server are running CF under JRun and others are running CF under WebSphere. I only noticed this issue because I had mapped one of our JRun servers and all of a sudden it had portions of the WebSphere directory structure on there. I think it had to do with a workspace in CFB but can't remember for sure. I fixed it a while back by removing the offending setting in CFB. Man, wish I could remember exactly what it was...
4. Re: Editing HTML file leaves temporary files lying about the place
Adam Cameron. Sep 11, 2012 6:17 AM (in response to Miguel-F)Come to think of it, I had another issue with CFB leaving bits around a while back.
Your one doesn't sound familiar. This is the worst one I've come across: http://forums.adobe.com/message/4555461#4555461
That's really annoying.
Adam
5. Re: Editing HTML file leaves temporary files lying about the place
Miguel-F Sep 11, 2012 6:29 AM (in response to Adam Cameron.)Actually my issue was similar to that one. It would create this deep folder hierarchy (because the WebSphere webroot is buried down deep in the folders) whenever I started CFB. My colleague kept blaming me for an inadvertant copy-paste (or worse, a folder drag) but I swore I never did. I finally tracked it down to CFB. If I can remember my resolution I will post back.
6. Re: Editing HTML file leaves temporary files lying about the place
Adam Cameron. Sep 11, 2012 6:33 AM (in response to Miguel-F)Cool cheers. What's weird is that it's always that /circuits/scheduledTask/generate/includes/ dir that the p2 dir gets created in. Even if I blow away /circuits/scheduledTask dir, the whole subdir tree gets recreated again so that the "p2" dir has a place to be created. There is absolutely nothing special about that /circuits/scheduledTask/generate/includes/ dir. It's one of about 5000 dirs in that application.
Adam
