4 Replies Latest reply on Nov 15, 2006 5:05 PM by DanM.
    document.window controls from flash
    DanM. Level 1
      i have an html form that manipulates the opened window with basic html such as
      <form action = "httpURL" target = "_self"
      onSubmit = "window.open('','paradigm','width=800,height=600,resizable=yes,toolbar=no,menubar=no,loca tion=no');">
      AND! .....
      i have a flash forum who does the same login, however, my window appears with toolbar, menubar, etc.
      i'm calling it with getURL ( URL, Window, POST)
      is there ANY way to make the new window appear without without a toolbar or menubar similar to the document.window property above.
      Thanks in advance, as this is extremely difficult to search in search engines as document and window are very common words.
        • 1. Re: document.window controls from flash
          Marghoob Suleman Level 1
          use attached script in your html <head> tag.
          and call a javascript method from flash.
          like this
          getURL("javascript:OpenPopup(' http://www.loveincafe.com/')")
          i hope it should work.
          • 2. Re: document.window controls from flash
            DanM. Level 1
            even though you didn't accomdate for my form variable to post to the "URL", you gave me the idea of calling javascript from within the getURL call. don't know why i never thought of it *bang head, idiot* ...anywayz.
            i think that is the only method is using the fs command or getURL to pass the values of the text boxes out to a js function that submits a "hidden" form.
            i'm sure i'll run into problems, so i'll be back :)
            • 3. Re: document.window controls from flash
              DanM. Level 1
              by the way, THANKS!!!
              • 4. Re: document.window controls from flash
                DanM. Level 1
                okay. worked once, but can't duplicated on the product computer. GRR!!!
                #my button AS:
                on (release) {
                getURL("javascript:insertValues('between this and "+UserId.text+"this')");
                #my JS function
                var user;
                function insertValues(user) {
                document.mercury.UserId.value=user;
                All it does is put everything BUT the content of my text box in it. so the "functionality" of it is good. but somehow ( UserId.text ) does not get it.
                yes, i copy and pasted the textbox name, no misspellings.
                my question:
                what's wrong with my AS syntax?
