1. Re: Raw converter
MichelBParis Sep 12, 2012 3:07 AM (in response to gman87)You don't open files in the conververter : you simply convert them into the DNG format. You can batch convert a whole folder.
2. Re: Raw converter
gman87 Sep 12, 2012 3:10 AM (in response to MichelBParis)Could you please explain how
3. Re: Raw converter
MichelBParis Sep 12, 2012 4:22 AM (in response to gman87)See the readme file of the latest vestion of the DNG converter:
http://www.adobe.com/special/photoshop/camera_raw/DNG_7.1_Converter_ReadMe.pdf
4. Re: Raw converter
gman87 Sep 12, 2012 5:09 AM (in response to MichelBParis)I have my files in DNG. I still cannot open them in ACR
5. Re: Raw converter
dj_paige Sep 12, 2012 5:14 AM (in response to gman87)gman87 wrote:
I can open my Raw files in PE9 however the files will not open in RAW converter.
You mean your RAW files open in the PSE9 Editor?
This is a symptom of having too few pixels vertically on your computer screen. You need to change the size of your computer screen, in pixels, to around 800 pixels vertically. I am not sure what the lower limit is, but 800 ought to work. There are some netbooks where you will not be able to make this change.
6. Re: Raw converter
gman87 Sep 12, 2012 5:19 AM (in response to dj_paige)Yes sorry I ment to say my Raw files open in PSE9 editor and not in ACR. I have tried converting them into DNG but the same thing is happening.
7. Re: Raw converter
99jon Sep 12, 2012 5:34 AM (in response to gman87)Download and install the latest free Adobe DNG converter to convert your CR2 files to the Adobe Raw format and the files will open in all versions of PSE (keep your original CR2’s as backup).
Windows download click here DNG Converter 7.1
Mac download click here DNG Converter 7.1
You can convert a whole folder of CR2 images in one click. See this quick video tutorial:
8. Re: Raw converter
dj_paige Sep 12, 2012 6:44 AM (in response to gman87)Yes sorry I ment to say my Raw files open in PSE9 editor and not in ACR. I have tried converting them into DNG but the same thing is happening.
Have you tried changing the size of your screen as I suggested?
9. Re: Raw converter
dj_paige Sep 12, 2012 6:44 AM (in response to 99jon)Download and install the latest free Adobe DNG converter to convert your CR2 files to the Adobe Raw format and the files will open in all versions of PSE (keep your original CR2’s as backup).
I don't think this addresses the stated symptoms.
10. Re: Raw converter
gman87 Sep 12, 2012 12:27 PM (in response to dj_paige)I have a monitor plugged into my netbook. The monitor seems to have sufficient pixels. However as its plugged directly into my netbook I'm not sure What effect this has. Are you suggesting I should not use my netbook as its screen is too small?
Re: Raw converter
created by dj_paige in Photoshop Elements - View the full discussion
Replies to this message go to everyone subscribed to this thread, not directly to the person who posted the message. To post a reply, either reply to this email or visit the message page: http://forums.adobe.com/message/4692817#4692817
To unsubscribe from this thread, please visit the message page at http://forums.adobe.com/message/4692817#4692817. In the Actions box on the right, click the Stop Email Notifications link.
Start a new discussion in Photoshop Elements by email or at Adobe Forums
For more information about maintaining your forum email notifications please go to http://forums.adobe.com/message/2936746#2936746.
11. Re: Raw converter
To be sure, check the display properties in Windows.
- right click somewhere on the desktop screen to get the popup where you should see the option : properties.
- choose parameters and see if the vertical resolution can be set at minimum 800 pixels.
12. Re: Raw converter
99jon Sep 12, 2012 12:48 PM (in response to gman87)Can you try testing directly from the Editor menu using a jpeg:
File >> Open As
Then navigate to a jpeg and choose Camera Raw from the file type drop down.
If you get the same results then it’s probably a short display problem as suggested by paige, or you have more than one version of Camera Raw.8bi installed. You can check by navigating to the File Formats Folder.
C:\Program Files (x86)\Common Files\Adobe\Plug-Ins\Elements 10\File Formats
N.B. Program Files on 32 bit systems.
13. Re: Raw converter
As I have never been in this situation, I can't say for sure, but if it doesn't work, then the netbook is most likely the problem.
14. Re: Raw converter
R_Kelly Sep 12, 2012 3:06 PM (in response to gman87)If you have a monitor plugged into your netbook set that as the primary monitor and use that instead of the netbook display.
What operating system?
15. Re: Raw converter
dj_paige Sep 12, 2012 3:33 PM (in response to R_Kelly)Some older netbooks do not allow you to increase the resolution to that of the primary monitor. I know, I have one.
16. Re: Raw converter
R_Kelly Sep 12, 2012 3:43 PM (in response to dj_paige)Okay that might be why the second monitor isn't making any difference.
Thanks for the info.
17. Re: Raw converter
gman87 Sep 13, 2012 2:09 AM (in response to gman87)Thanks for all your suggestions. I have found my netbook max resolution to be 1024 x 600. Therefore a short display seems to be the issue. I have tried making my second monitor the primary one, however it doesnt seem to like this. I have tried opening a jpeg in the editor as a raw file, this also just opens in the editor. I am running XP pro. I shall keep trying to get my second monitor to act as the primary as I see this as the only solution to this problem.
18. Re: Raw converter
R_Kelly Sep 13, 2012 2:32 AM (in response to gman87)You might do google search for your netbook and using a second monitor or maybe your users manual has same hints about how and/or limitations when using a second monitor.
On my labtop with a secondary monitor you can set the second monitor screen resolution higher, but it might be as dj_paige suggested that some netbooks won't allow that.
19. Re: Raw converter
gman87 Sep 15, 2012 4:08 AM (in response to gman87)Thanks guys. I have managed to finally get ACR working by using my plug in monitor as the primary monitor.
20. Re: Raw converter
R_Kelly Sep 15, 2012 4:10 AM (in response to gman87)Good to hear and thanks for letting us know.
