6 Replies Latest reply on Sep 12, 2012 3:15 PM by LightPaintingPictures
    Premeire CS6 moving Extremly Slow/Laggy
      The title says it all, and this is extremly fustrating.  Im in the middle of a project in premeiere CS6 and it moves so slow and unresponsive I cant possible even finish.  Is there some sort of solution, I get the exact same results on 3 Mac computers.  An iMac 27in iMac 21inch and Macbook Pro.   Turn on and off open GL nothing works on all systems.  CS5.5 worked like a charm.  Any solutions, or is it off to final cut?
        • 1. Re: Premeire CS6 moving Extremly Slow/Laggy
          LightPaintingPictures Level 1
          Processor  2.66ghz Intel i7
          Memory 8 gb 1067 MHz DDR3
          Intel HD Graphics:
            Chipset Model:          Intel HD Graphics
            Type:          GPU
            Bus:          Built-In
            VRAM (Total):          288 MB
            Vendor:          Intel (0x8086)
            Device ID:          0x0046
            Revision ID:          0x0018
            gMux Version:          1.9.21
            Displays:
          Color LCD:
            Resolution:          1440 x 900
            Pixel Depth:          32-Bit Color (ARGB8888)
            Main Display:          Yes
            Mirror:          Off
            Online:          Yes
            Built-In:          Yes
          NVIDIA GeForce GT 330M:
            Chipset Model:          NVIDIA GeForce GT 330M
            Type:          GPU
            Bus:          PCIe
            PCIe Lane Width:          x16
            VRAM (Total):          512 MB
            Vendor:          NVIDIA (0x10de)
            Device ID:          0x0a29
            Revision ID:          0x00a2
            ROM Revision:          3560
            Displays:
          Display Connector:
            Status:          No Display Connected
          Display Connector:
          • 2. Re: Premeire CS6 moving Extremly Slow/Laggy
            Thats the laptop Specs that Im currently using, Both the iMac computers are 2011 and 2012 one with thunder bolt the other with out, and they all run slow with this program.
            • 3. Re: Premeire CS6 moving Extremly Slow/Laggy
              Greg Baber Adobe Employee
              It can depend on the footage you are working with.  Some footage requires more system resources.  I will say that 8 GB is low for CS6.  It will work, but it is the minimum system requirement.
              • 4. Re: Premeire CS6 moving Extremly Slow/Laggy
                my computer is actually double the recomended 4gb ram requirements.  and i havent seen a laptop with more than 8gb.  further more my iMac has 32gb and still the same result.  im using dslr footage
                • 5. Re: Premeire CS6 moving Extremly Slow/Laggy
                  You are right, 4 GBs is the minimum, 8 is the recommended, my mistake.
                  There is something in the configuration that is causing the problem - many of our customers use Mac, including myself, without any performance issues.
                  Where are the files located, and what codec is the footage using?
                  • 6. Re: Premeire CS6 moving Extremly Slow/Laggy
                    Im uninstalling this software and counting my losses.   Not a professional editing platform.  After hours of searching online there are no available solutions.  And MANY others are experiencing the exact same thing as I am and I've tried on 3 Mac computers all recent models and the same result.  All of my computers are at least $2500 a piece and have the maximum amount of ram available and its not enough.  Last year I edited an event with Premiere Pro CS5.5 with no problems, and this year the same event I have to start editing again from scratch because I cant even open it in CS5.5.  Im a die hard Adobe customer but this really does it form me in terms of CS6 im OFFICIALLY DONE.  I cant even finish a 3hr project that I've been working on its that bad.  Definantly not recommending this to ANYBODY that puts any sort of value on there time.
