I have Robohelp 9 installed on a machine that has a questionable drive. How can I uninstall Robohelp from this machine and install it on another. The problem is that Robohelp only allows 2 versions to be installed and I'm afraid that if I uninstall it that I will not be able to install it on another 64bit machine.
Any suggestions?
All you need to do is to deactivate the licence so it can be activated on the other PC. There is a Help > Deactivate menu item that allows you to do this. Then it is just a case of installing RH9 on your new PC and activating RH9 again.
Thanks.
