2 Replies Latest reply on Sep 19, 2012 8:04 PM by David Beaudet
    Only a type can be imported. org.apache.felix.scr.annotations.Component resolves to a package
    ravindrareddydr Level 2
      I copied the example code exactly, but it won't compile. I receive errors on all the annotations, like:
      "Only a type can be imported. org.apache.felix.scr.annotations.Component resolves to a package"
      and
      "Component cannot be resolved to a type"
      package com.day.cq.wcm.apps.geometrixx.impl;
      import com.day.cq.workflow.WorkflowException;
      import com.day.cq.workflow.WorkflowSession;
      import com.day.cq.workflow.exec.WorkItem;
      import com.day.cq.workflow.exec.WorkflowData;
      import com.day.cq.workflow.exec.WorkflowProcess;
      import com.day.cq.workflow.metadata.MetaDataMap;
      import org.apache.felix.scr.annotations.Component;
      import org.apache.felix.scr.annotations.Properties;
      import org.apache.felix.scr.annotations.Property;
      import org.apache.felix.scr.annotations.Service;
      import org.osgi.framework.Constants;
      import org.slf4j.Logger;
      import org.slf4j.LoggerFactory;
      import javax.jcr.Node;
      import javax.jcr.RepositoryException;
      * Sample workflow process
      @Component
      @Service
      @Properties({
      @Property(name = Constants.SERVICE_DESCRIPTION, value = "A sample workflow process implementation."),
      @Property(name = "process.label", value = "Sample Workflow Process")})
      public class CustomWorkflow implements WorkflowProcess {
      private static final String TYPE_JCR_PATH = "JCR_PATH";
      private static final Logger log = LoggerFactory.getLogger(CustomWorkflow.class);
      public void execute(WorkItem item, WorkflowSession session, MetaDataMap args) throws WorkflowException {
      WorkflowData workflowData = item.getWorkflowData();
      if (workflowData.getPayloadType().equals(TYPE_JCR_PATH)) {
      String path = workflowData.getPayload().toString();
      // More code here
      Errors :
      DescriptionResourcePath
      Component cannot be resolved to a type.java/li
      Only a type can be imported. org.apache.felix.scr.annotations.Component resolves to a package.java/li
      Properties cannot be resolved to a type.java/l
      Service cannot be resolved to a type.java
