4 Replies Latest reply on Sep 14, 2012 2:46 AM by B4stien
    Exporting package and compressing it as a ZIP in ActionScript
    B4stien Level 1
      Hi everyone,
      Our users need to be able to export InDesign packages to our remote web app directly from our InDesign extension. Compressing it to ZIP is probbaly the best option.
      I saw that this question had already been asked and answered for JavaScript (http://forums.adobe.com/message/4243513#4243513). My question is, is there a good zip library for actionscript out there; the few I found haven't been maintained for years. Or is the best option to also use JsZip here? I wish I could use command line tools, but our users work on a large variety of OS and we can't guarantee that they will have the proper tools installed.
      Thanks in advance for your help.
      - Bastien
        • 1. Re: Exporting package and compressing it as a ZIP in ActionScript
          lomorgan Adobe Employee
          I can't officially endorse anything, but I've used fzip before (http://codeazur.com.br/lab/fzip/), which now seems to be part of as3commons: http://www.as3commons.org/as3-commons-zip/index.html. From what I remember it worked pretty well. There's some sample code here for archive creation: http://wahlers.com.br/claus/blog/fzip-alpha-release-create-and-modify-zip-archives/, though this was before it moved to as3commons, so I think the class names will have changed slightly.
          Hope that helps,
          Louis
          • 2. Re: Exporting package and compressing it as a ZIP in ActionScript
            Loic.Aigon Adobe Community Professional
            I did zip files once in a applescript by using the shell zip command. I would give the NativeProcess a chance to use the system tool for zipping files. I guess there is a native command in Windows as well. I am soon doing this and this is the lead I will investigate first.
            Best,
            Loic
            • 3. Re: Exporting package and compressing it as a ZIP in ActionScript
              Harbs. Level 6
              I've tested a couple of different zip utilities, and FZip worked best.
              • 4. Re: Exporting package and compressing it as a ZIP in ActionScript
                B4stien Level 1
                Thanks everyone,
                I followed Louis and Harbs' advice and used the fzip (now as3common) library, and it works like a charm. Here's some experimental code I used (obviously it's missing some folder cleaning):
                public class MultiplePagesUploader      {
                     private var zip:Zip;
                     private var filesToCompress:int = 1;
                     private var filesCompressed:int = 0;
                     public function extractPackage(exportFolderPath:String):void{
                          var indDesignApp:Application = InDesign.app;
                          var doc:Document = indDesignApp.activeDocument;
                          var exportFolder:File = File.createTempDirectory();
                          doc.packageForPrint(exportFolder, true, true, true, false, true, false, false);
                          zip = new Zip();
                          addFileToZip(exportFolder, zip);
                     public function fileAddedToZip():void{
                           filesCompressed++;
                          if (filesToCompress == filesCompressed){
                               var tempDir:File = File.createTempDirectory();
                               var zipFile:File = new File(tempDir.nativePath + "/indd_package_test.zip");
                               var stream:FileStream = new FileStream();
                               stream.open(zipFile, FileMode.WRITE);
                               zip.serialize(stream);
                               stream.close();
                     public function addFileToZip(file:File, zip:Zip, path:String=""):void{
                           if(file.isDirectory){
                                var directory:Array = file.getDirectoryListing();
                               filesToCompress = filesToCompress + directory.length;
                               for each (var f:File in directory){
                                     addFileToZip(f, zip, path + "/" + file.name);
                               fileAddedToZip();
                           }else{
                                file.addEventListener(flash.events.Event.COMPLETE, function():void{
                                     zip.addFile(path + '/' + file.name, file.data);
                                     fileAddedToZip();
                                file.load();
                Someone might find it useful.
                Cheers
