2 Replies Latest reply on Aug 26, 2006 10:35 PM by Newsgroup_User
    Dreamweaver on PDA
    LLofland
      Are there any applications to use Dreamweaver on a PDA
        • 1. Re: Dreamweaver on PDA
          Level 7
          > ...applications to use Dreamweaver on a PDA
          What does that mean...application to USE Dreamweaver? Dreamweaver is an
          application. Application software is defined subclass of computer software
          that employs the capabilities of a computer directly to a task that the user
          wishes to perform. This should be contrasted with system software which is
          involved in integrating a computer's various capabilities, but typically
          does not directly apply them in the performance of tasks that benefit the
          user. The term application refers to both the application software and its
          implementation.
          You can't possibly mean developing websites with DW on a PDA can you?
          Confused.
          • 2. Re: Dreamweaver on PDA
            Level 7
            If you mean you want to edit a webpage using a PDA, do a google search on
            html editor and the pda's OS.
            there's probably not much beyond some small apps that integrate a text
            editor and FTP.
            If you need to edit on the fly but can get to a real computer with net
            access and a common web browser- there are server side solutions. The
            CPanel used with a lot of hosting accounts has a built in text editor and
            file manager- as long as you remember the login you can edit the raw code of
            any page on the site from anyplace. Most of these wouldn't work or you
            wouldn't want to try using a PDA screen.
            There's no way to run dreamweaver or anything with a tenth it's capabilities
            from a PDA.
