1. Re: How can I determine the rotate angle of an artLayer?
c.pfaffenbichler Sep 14, 2012 12:16 AM (in response to xpertpse)What are you talking about?
Smart Objects or regular Layers (of the various kinds)?
2. Re: How can I determine the rotate angle of an artLayer?
xpertpse Sep 14, 2012 12:47 AM (in response to c.pfaffenbichler)I am talking about the regular layers.
3. Re: How can I determine the rotate angle of an artLayer?
c.pfaffenbichler Sep 14, 2012 1:09 AM (in response to xpertpse)I may be misunderstanding youe question, but if you rotate a pixel Layer and once the rotation step is not in the History or in a Log anymore, then there is no real (edit: in the sense of enabling Photoshop to determine it unequivocally) information on whether and how much it has been rotated.
Image content like discernable stripes may make it clear to you that an element has been rotated, but that is hardly for Photoshop to decide.
One could evaluate a Layer’s transparency to see if it more or less conforms to a rectangle and then determine the angles, but as the Layer may have been created that way that would seem to be a judgement call.
4. Re: How can I determine the rotate angle of an artLayer?
xpertpse Sep 14, 2012 1:44 AM (in response to c.pfaffenbichler)Thanks for your quick responses. Yes, you are right. One can not determine the rotate angle.
Is the above understanding different if the layer would have been Smart Objects. Can we determine the angle then?
Also, i have another question related to rotate. I am fetching the bounds of a layer, then i am rotating the layer via certain angle and then again fetching the bounds. The both bounds are coming same. This should not be the case because after rotating the layer, the bounding rectangle to the layer changes and hence the bounds should change. Do I need to save the document after rotating the layer and then fetch the bounds again?
Thanks again.
5. Re: How can I determine the rotate angle of an artLayer?
Muppet Mark Sep 14, 2012 2:34 AM (in response to xpertpse)Untried but have you app.refresh() between the rotate and get new bounds… don't know it that will make a difference?
6. Re: How can I determine the rotate angle of an artLayer?
c.pfaffenbichler Sep 14, 2012 2:50 AM (in response to xpertpse)if the layer would have been Smart Objects. Can we determine the angle then?
I’m afraid while the information naturally has to be stored I don’t know how to access it or if it is even possible.
Could the layer have almost invisible pixels that basically make it square?
Apart from Mark’s recommendation I don’t know how to remedy that either, but in a quick test the bounds seem to update on my station.
Are you sure you got the bounds anew after the transformation and have not set a variable of the bounds prior?
7. Re: How can I determine the rotate angle of an artLayer?
c.pfaffenbichler Sep 14, 2012 7:45 AM (in response to xpertpse)If you know that a Layer is a rotated rectangule one could, as mentioned earlier, try to use its transparency to determine the rotation to the closest 90˚ – if it had been rotated 180˚ for example that would not register.
8. Re: How can I determine the rotate angle of an artLayer?
r-bin Sep 16, 2012 7:11 AM (in response to xpertpse)You can create a linked and disabled vector mask with only two ancor points and determine the rotation of the layer via calculations points coordinates.
9. Re: How can I determine the rotate angle of an artLayer?
xpertpse Sep 16, 2012 12:13 PM (in response to c.pfaffenbichler)If you know that a Layer is a rotated rectangule
Yes. The layer is a rotated rectangle. Please elaborate on how can i fetch the transparency values and how can i calculate the rotation to the closest 90.
Thanks again.
10. Re: How can I determine the rotate angle of an artLayer?
Michael L Hale Sep 16, 2012 1:27 PM (in response to xpertpse)You can't get the angle directly from the layer's transparency. You can load the transparency as a selection. Make a path from that selection. Then examine the pathPoints to find an angle in the path. With a simple rectanglar shaped layer you should be able to get close to the correct angle if it was only rotated once and less than +- 89 degrees.
function loadTransparency(){ var desc = new ActionDescriptor(); var ref = new ActionReference(); ref.putProperty( charIDToTypeID( "Chnl" ), charIDToTypeID( "fsel" ) ); desc.putReference( charIDToTypeID( "null" ), ref ); var ref1 = new ActionReference(); ref1.putEnumerated( charIDToTypeID( "Chnl" ), charIDToTypeID( "Chnl" ), charIDToTypeID( "Trsp" ) ); desc.putReference( charIDToTypeID( "T " ), ref1 ); executeAction( charIDToTypeID( "setd" ), desc, DialogModes.NO ); }; function makePathFromSelection() { var desc = new ActionDescriptor(); var ref = new ActionReference(); ref.putClass( charIDToTypeID('Path') ); desc.putReference( charIDToTypeID('null'), ref ); var channelRef = new ActionReference(); channelRef.putProperty( charIDToTypeID('csel'), charIDToTypeID('fsel') ); desc.putReference( charIDToTypeID('From'), channelRef ); desc.putUnitDouble( charIDToTypeID('Tlrn'), charIDToTypeID('#Pxl'), 2.000000 ); executeAction( charIDToTypeID('Mk '), desc, DialogModes.NO ); }; function activePathIndex(){ try{ var ref = new ActionReference(); ref.putEnumerated( charIDToTypeID("Dcmn"), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") ); var desc = executeActionGet( ref ); return desc.getInteger(charIDToTypeID("TrgP" )); }catch(e){} }; function measureAngle(path){ var res = new Array; var lineStart = path.subPathItems[0].pathPoints[0].anchor; var lineEnd = path.subPathItems[0].pathPoints[1].anchor; var a = Math.max(lineStart[0],lineEnd[0])-Math.min(lineStart[0],lineEnd[0]); var o = Math.max(lineStart[1],lineEnd[1])-Math.min(lineStart[1],lineEnd[1]); var c = Math.round(Math.sqrt((a*a)+(o*o))); res.push(c); var ang = (180/Math.PI) * Math.atan2(o,a); if(lineStart[1] < lineEnd[1]){//negative angle ang = -ang; }; res.push(ang); return res; }; loadTransparency(); makePathFromSelection(); var tempPath = app.activeDocument.pathItems[activePathIndex()]; var angle = measureAngle( tempPath )[1]; tempPath.remove(); alert( Math.abs(angle) );
