Hi All
I have a bit of a problem and I am hoping someone can help me out. I was given a flash.exe file by a client and he wants it putting on his website (Business Catalyst Website).
I have converetd the exe file to swf and it has given me 4 SWF files,
I have out into place the following code:
<object height="400" width="600">
<param name="movie" value="/Proludic/00000004.swf">
<embed src="/Proludic/00000004.swf" height="400" width="600">
</object>
Should show a loading bar and then load up the application which is all in the same folder. It keeps coming up with a error code.
http://6sm.co.uk/proludic-flash-test
That is the link I am testing it on and it doesnt seem to work or load the files I want. There are 4 xml files which are different languages.
Can anyone help?
Thank you
Asad Ali
Hi Asad,
Error 2032 is a "Stream Error". Would you mind reposting this question over in the Flash Pro forums? This forum is typically geared for general usage of Flash Player and the other forum will give you a wider developer audience.
http://forums.adobe.com/community/flash
Chris
