1 Reply Latest reply on Sep 15, 2012 2:22 AM by Kasyan Servetsky
    Getting xmlcontent string from xmlElement object
    TD_TAD Level 1
      Hello All,
      Suppose paragraph in text frame contains xml structure as,
      <p>
      <bold><italic>Hello</italic></bold>
      Hello friends
      </p>
      When I get contents of xmlElement P it gives only strings "Hello Hello friends", but I want it as,  "<p><bold><italic>Hello</italic></bold>Hello friends</p>".
      Is there any simple way to get this? Without exporting P tag as xml and reading that xml back
      Please help me out.
      Regards,
      Tahir
        • 1. Re: Getting xmlcontent string from xmlElement object
          Kasyan Servetsky Level 5
          I would handle this task like so:
          Main();
          function Main() {
                          var xmlElement
                          var doc = app.activeDocument;
                          var xmlRoot = doc.xmlElements[0];
                          var xmlElements = xmlRoot.evaluateXPathExpression("//p");
                          for (var i = 0; i < xmlElements.length; i++) {
                                          xmlElement = xmlElements[i];
                                          var xmlContent = xmlElement.xmlContent;
                                          var xmlFile = new File("~/Desktop/Temp.xml");
                                          xmlElement.exportFile(ExportFormat.XML, xmlFile, false);
                                          var str = ProcessFile(xmlFile);
                                          $.writeln(i + " - " + str);
          function ProcessFile(file) {
                          file.open("r");
                          var txt = file.read();
                          file.close();
                          txt = txt.replace('<?xml version="1.0" encoding="UTF-8" standalone="yes"?>\n', '');
                          return txt;
          Export every xml-element to a temporary xml-file, read it and remove the XML declaration line.
          Here is how my test file looks like:
          This is the result I get in console:
          Hope this helps.
          Kasyan
