2 Replies Latest reply on Sep 17, 2012 9:38 AM by Cleanshooter21
    Combine 2 different scripts
    acevans001
      i have a few different scripts that I use ALOT! I was wondering if any knew of a way to combine them.
      One make the ai file a pdf the smallest file size and the other makes the pdf hi-res for printing purposes and adds the word PRINT before the file extension
      I did not write these, however I did edit them for my purposes
      Save as PDFs smalles file size without name.js
      DESCRIPTION
      This sample gets files specified by the user from the
      selected folder and batch processes them and saves them
      as PDFs in the user desired destination with the same
      file name.
      // Main Code [Execution of script begins here]
      // uncomment to suppress Illustrator warning dialogs
      app.userInteractionLevel = UserInteractionLevel.DONTDISPLAYALERTS;
      var destFolder, sourceFolder, files, fileType, sourceDoc, targetFile, pdfSaveOpts;
      // Select the source folder.
      sourceFolder = Folder.selectDialog( 'Select the folder with Illustrator files you want to convert to PDF', '~' );
      // If a valid folder is selected
      if ( sourceFolder != null )
      files = new Array();
      fileType = "*.ai"; //prompt( 'Select type of Illustrator files to you want to process. Eg: *.ai', ' ' );
      // Get all files matching the pattern
      files = sourceFolder.getFiles( fileType );
      if ( files.length > 0 )
      // Get the destination to save the files
      destFolder = sourceFolder;
      for ( i = 0; i < files.length; i++ )
      sourceDoc = app.open(files[i]); // returns the document object
      // Call function getNewName to get the name and file to save the pdf
      targetFile = getNewName();
      // Call function getPDFOptions get the PDFSaveOptions for the files
      pdfSaveOpts = getPDFOptions( );
      // Save as pdf
      sourceDoc.saveAs( targetFile, pdfSaveOpts );
      sourceDoc.close();
      alert( 'Files are saved as PDF in ' + destFolder );
      else
      alert( 'No matching files found' );
      getNewName: Function to get the new file name. The primary
      name is the same as the source file.
      function getNewName()
      var ext, docName, newName, saveInFile, docName;
      docName = sourceDoc.name;
      ext = '.pdf'; // new extension for pdf file
      newName = "";
      for ( var i = 0 ; docName[i] != "." ; i++ )
      newName += docName[i];
      newName += ext; // full pdf name of the file
      // Create a file object to save the pdf
      saveInFile = new File( destFolder + '/' + newName );
      return saveInFile;
      getPDFOptions: Function to set the PDF saving options of the
      files using the PDFSaveOptions object.
      function getPDFOptions()
      { var NamePreset = '[Smallest File Size]';
      // Create the PDFSaveOptions object to set the PDF options
      var pdfSaveOpts = new PDFSaveOptions();
      // Setting PDFSaveOptions properties. Please see the JavaScript Reference
      // for a description of these properties.
      // Add more properties here if you like
      pdfSaveOpts.acrobatLayers = true;
      pdfSaveOpts.colorBars = false;
      pdfSaveOpts.colorCompression = CompressionQuality.AUTOMATICJPEGHIGH;
      pdfSaveOpts.compressArt = true; //default
      pdfSaveOpts.embedICCProfile = false;
      pdfSaveOpts.enablePlainText = true;
      pdfSaveOpts.generateThumbnails = true; // default
      pdfSaveOpts.optimization = true;
      pdfSaveOpts.pageInformation = false;
      pdfSaveOpts.pDFPreset = NamePreset;
      // uncomment to view the pdfs after conversion.
      // pdfSaveOpts.viewAfterSaving = true;
      return pdfSaveOpts;
      sourceFolder = Folder.selectDialog( 'Select the folder with Illustrator .ai files you want to convert to PDF');
              //destFolder = Folder.selectDialog( 'Select the folder where you want to save the converted PDF files.', '~' );
                  // Save as pdf
                  sourceDoc.close();
          else
          ext = ' - PRINT.pdf'; // new extension for pdf file
          newName = "";
          return saveInFile;
      { var NamePreset = 'Print with Bleeds';
      pdfSaveOpts.pageInformation = true;
      return pdfSaveOpts;
        • 1. Re: Combine 2 different scripts
          Muppet Mark Level 5
          At the moment Im not sure… Would have to test… At present having 2 scripts open original *.ai files and do a save as then close… Combining would mean the active document would be the *.pdf after the first save as… It may be possible to undo that stage or you may want to make the better quality PDF first… Not sure all that syntax is required either…
          • 2. Re: Combine 2 different scripts
            Cleanshooter21 Level 1
            This might do the trick...
            DESCRIPTION
            file name.
            //app.userInteractionLevel = UserInteractionLevel.DONTDISPLAYALERTS;
            var destFolder, sourceFolder, files, fileType, pdfs, sourceDoc, targetFileSmall, targetFileLarge, pdfSaveOptsSmall, pdfSaveOptsBig;
            if ( sourceFolder != null ){
                if ( files.length > 0 ){
                    for (var i = 0; i < files.length; i++ ){
                        targetFileLarge = getNewName(true);
                        pdfSaveOptsLarge = getPDFOptions(true);
                        // Save as pdf
                        sourceDoc.saveAs( targetFileLarge, pdfSaveOptsLarge );
                        sourceDoc.close();
                }else{
                pdfs = new Array();
                fileType = "*.pdf"; //prompt( 'Select type of Illustrator files to you want to process. Eg: *.ai', ' ' );
                pdfs = sourceFolder.getFiles (fileType);
                if ( pdfs.length > 0 ){
                        sourceDoc = app.open(pdfs[i]); // returns the document object
                        targetFileSmall = getNewName(false);
                        pdfSaveOptsSmall = getPDFOptions(false);
                        // Save as pdf
                        sourceDoc.saveAs( targetFileSmall, pdfSaveOptsSmall );
                        sourceDoc.close();
                }else{
            function getNewName(print){
                if(print){
                }else{
                newName = "";
                for ( var i = 0 ; docName[i] != "." ; i++ ){
                return saveInFile;
            function getPDFOptions(large){
                if(large){
                }else{
                pdfSaveOpts.viewAfterSaving = false;
                return pdfSaveOpts;
