4 Replies Latest reply on Sep 16, 2012 2:36 AM by David_Entwistle
    Isometric transformation
    David_Entwistle Level 1
      In the hope that this will be a considerable boon to mankind, I'm trying to write a script to convert orthogonal ('normal-looking') artwork into any of four isometric views.
      The sequence to achieve any of the four views is:
      • vertical scale (86.602%)
      • shear (30° or –30°)
      • rotate (30° or –30°)
      The vertical scale and rotate operations look straightforward enough; but the shear needs a transform matrix that is nowhere to be found in Adobe's Javascript documentation. (Or indeed anywhere on the web, so it seems.)
      I am not much of a mathematician, and (in England, at any rate) a shear transform matrix would come under the heading of Very Hard Sums.
      Can someone with more acquaintance with math help out?
      Many thanks.
        • 1. Re: Isometric transformation
          W_J_T Level 4
          I have been at odds with the matrix as well. ;-)
          Maybe this will help? Its concerning Flash but its dealing with Transform Matrix and should be quite relative to illustrators matrix I think? http://www.senocular.com/flash/tutorials/transformmatrix/
          • 2. Re: Isometric transformation
            Thank you - that reference looks very comprehensive. I'll look through it and see if I can apply it. (But neither of us should hold their breath meanwhile!)
            • 3. Re: Isometric transformation
              Muppet Mark Level 5
              Matrix are quite weird I must admit… The app does however give you some built-in methods to obtaining this math… Here is an example of a couple that may help you get your head around it… each matrix's values are wrote to the console so you can see the values… Try with a simple rectangle… Unfortunatly these are not live but applied…
              #target illustrator
              transformStuff();
              function transformStuff() {
                        var doc, i, p, m, sM,rM, srM;
                        doc = app.activeDocument;
                        p = doc.pageItems[0];
                        m = app.getIdentityMatrix();
                        for ( i in m ) { $.writeln( m[i] ); }
                        p.transform( m ); app.redraw();
                        alert( 'Does Nothing…' ); app.undo();
                        sM = app.getScaleMatrix( 100, 86.602 );
                        for ( i in sM ) { $.writeln( sM[i] ); }
                        p.transform( sM ); app.redraw();
                        alert( 'Scaled…' ); app.undo();
                        rM = app.getRotationMatrix( 30 );
                        for ( i in rM ) { $.writeln( rM[i] ); }
                        p.transform( rM ); app.redraw();
                        alert( 'Rotated…' ); app.undo();
                        srM = concatenateMatrix( sM, rM );
                        for ( i in srM ) { $.writeln( srM[i] ); }
                        p.transform( srM ); app.redraw();
                        alert( 'Scaled & Rotated…' );
              • 4. Re: Isometric transformation
                Hi Mark
                Thank you - that welcome chunk of code promises to be very helpful. Since I last wrote I've learned that it's possible to carry out a shear by combining a rotation with a non-uniform scale, both of which are covered by your code. The question I now need to address is how much rotation and scale add up to a shear of 30°! Will write again when I've made progress.
                Thanks again for your generosity.
