1 Reply Latest reply on Sep 15, 2012 9:49 AM by mkalyanp
    Animations after the first slide are not working in Presenter 8
    mrtsavich
      I've created a powerpoint with lots of step by step equations synced to audio.  Presenter is handling the first animation on the first slide ok, but it is not animating the rest of the content on the rest of the slides.  The content is just showing up all at once.  When I attempt to sync the audio with the animations, the editing command makes it appear like everything will work fine, but when I publish the document to pdf or to flash, the animations are failing to animate.
