1 Reply Latest reply on Feb 20, 2008 11:45 AM by jfillman
    Spanning columns in a grid messes up column widths
    Dustin_C
      Hi. I've been struggling with some layout issues when using column width percentages with the Flex Grid control. It seems that if I add a column that spans 2 or more columns, the column widths of the entire grid are altered. The strange thing is that the column widths are changed only if the text in the colspan column exceeds the width of the text in cells above or below it. Please see the code sample at the bottom of this message for a demonstration (I can't seem to find a way to "attach code").
      Does anyone have any ideas how to fix this?
      Thanks!
      Dustin
      <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" creationComplete="init()" layout="vertical">
      <mx:Script>
      <![CDATA[
      import mx.containers.*;
      import mx.controls.*;
      import mx.core.*;
      import flash.utils.Timer;
      import flash.events.TimerEvent;
      private var dynamicText:Text;
      private var charCode:uint;
      private var button:Button;
      private function init():void
      var panel:Panel = createPanel();
      addChild(panel);
      addText(panel);
      addGrid(panel);
      addButton(panel);
      startTimer();
      private function timerComplete(event:TimerEvent):void
      button.enabled = true;
      private function createPanel():Panel
      var panel:Panel = new Panel();
      panel.title = "ColSpan Spacing Problem";
      panel.width = 500;
      panel.height = 200;
      panel.horizontalScrollPolicy = ScrollPolicy.OFF;
      panel.layout = "vertical";
      return panel;
      private function addText(panel:Panel):void
      var text:Text = new Text();
      text.text = "First row contains 5 columns with no col spans. Second row contains 4 columns with " +
      "column 2 spanning columns 2 and 3. Notice how the column widths are affected when the text " +
      "in the colspan cell grows larger than the text in the cell above it.";
      text.percentWidth = 100;
      panel.addChild(text);
      private function addGrid(panel:Panel):void
      var grid:Grid = new Grid();
      grid.setStyle("horizontalGap", "0");
      grid.setStyle("verticalGap", "0");
      grid.percentWidth = 100;
      panel.addChild(grid);
      // FIRST ROW
      var gridRow:GridRow = new GridRow();
      gridRow.percentWidth = 100;
      grid.addChild(gridRow);
      var gridItem:GridItem = new GridItem();
      gridItem.setStyle("borderStyle", "solid");
      gridItem.percentWidth = 1;
      gridRow.addChild(gridItem);
      gridItem = new GridItem();
      gridItem.percentWidth = 48;
      text.text = "No ColSpan Columns";
      gridItem.addChild(text);
      gridItem.colSpan = 1;
      gridItem.clipContent = false;
      gridItem.percentWidth = 13;
      gridItem.percentWidth = 37;
      // SECOND ROW
      gridRow = new GridRow();
      gridItem.colSpan = 2;
      dynamicText = new Text();
      dynamicText.text = "A"; //IF THIS TEXT GROWS WIDER THAN TEXT IN THE ROW ABOVE, SPACING IS THROWN OFF
      gridItem.addChild(dynamicText);
      private function addButton(panel:Panel):void
      button = new Button();
      button.label = "Start Over";
      button.addEventListener(MouseEvent.CLICK, startOver);
      panel.addChild(button);
      private function startOver(event:MouseEvent):void
      startTimer();
      private function startTimer():void
      charCode = 66;
      button.enabled = false;
      var myTimer:Timer = new Timer(250, 25);
      myTimer.addEventListener(TimerEvent.TIMER, timerHandler);
      myTimer.addEventListener(TimerEvent.TIMER_COMPLETE, timerComplete);
      myTimer.start();
      private function timerHandler(event:TimerEvent):void
      dynamicText.text += String.fromCharCode(charCode);
      charCode++;
      </mx:Script>
      </mx:Application>
