4 Replies Latest reply on Sep 18, 2012 12:09 AM by Miguel Otz
    Search refereces by grep and get page in file text
    Miguel Otz
      I have a indesign files with texts and tables in 20 pages. The document is a references catalog. I need to get all reference and in what page there are. All result save in a text file.
      I think that the best mode is looking a reference with grep, but i don´t know how to make with  tables and get the content.
      Please, could you help me?
      The structure of references is /d/d/d/./d/d/d/./d/d/d
      When i run this script in only textframe go on, but if i have table, give me attachment error
      Thank very much.
      Bye
      Miguel
      Attachment error:
      Attachment Script:
      myDoc = app.activeDocument;
      log1 = makeLogFile("/Users/mcolmenero/Desktop/","test",myDoc,true);
      var myDocument = app.activeDocument;
      var myPages=myDocument.pages;
      var myRange=[];
      // clear find change text preferences before search
      app.findGrepPreferences = NothingEnum.NOTHING;
      app.changeGrepPreferences = NothingEnum.NOTHING;
      app.findGrepPreferences.findWhat = "(\\d\\d\\d)(\.)(\\d\\d\\d)(\.)(\\d\\d\\d)";
      var myNumPages = app.activeDocument.pages.length;
      var texto="";
      for (var i=0; i<myNumPages;i++){
           myRange = myRange.concat(myDocument.pages.item(i).textFrames.everyItem().getElements());
          var formatGrep=theGrepFinder("(\\d\\d\\d)(\.)(\\d\\d\\d)(\.)(\\d\\d\\d)",myRange);
          formatGrep.constructor.name;
          var num=formatGrep.length;
          if (num>0){
          var valor=formatGrep[0].contents;
          texto=texto+ "valor "+valor+" \tpag "+i+"\n";
      log(log1, texto);
      log1.execute();
          // Funciones varias
      function theGrepFinder(grepFindIt,theRange){
          app.findGrepPreferences.findWhat = grepFindIt;
          var retVal;
        for(var i=0;i<theRange.length;i++){
              retVal =(theRange[i].findGrep());
      return retVal;
      }//end theGrepFinder
      function makeLogFile(ruta,aName, aDoc, deleteIt) {
        var logLoc=ruta; // path to folder that will hold log file
        try {
          logLoc = aDoc.filePath;
        } catch (e) {
          logLoc = getScriptPath().parent.fsName
        var aFile = File(logLoc + "/" + aName + ".txt");
        if (deleteIt) {
          aFile.remove();
          return aFile;
        var n = 1;
        while (aFile.exists) {
          aFile = File(logLoc + "/" + aName + String(n) + ".txt");
          n++
        return aFile
      function log(aFile, message) {
        var today = new Date();
        if (!aFile.exists) {
          // make new log file
          aFile.open("w");
          aFile.write(String(today) + "\nLas referencias encontradas son:\n");
          aFile.close();
        aFile.open("e");
        aFile.seek(0,2);
        aFile.write("\n" + message);
        aFile.close();
        • 1. Re: Search refereces by grep and get page in file text
          thor2112
          Hi Miguel,
          Would something like this work?  I also added ^ and $ to the regex to be more exact, which I don't know if you'll want.  I've never worked with tables before - do they always exist in textFrames?  If so, I'm assuming you could just loop through each textFrame.
          var doc = app.activeDocument;
          var pageArray = doc.pages;
          var txt = '';
          app.findGrepPreferences = NothingEnum.nothing;
          app.changeGrepPreferences = NothingEnum.nothing;
          app.findGrepPreferences.findWhat = '^\\d{3}\\.\\d{3}\\.\\d{3}$';
          for (var p = 0; p < pageArray.length; p++) {
              var pg = pageArray[p];
              var textFrameArray = pg.textFrames;
              for (var t = 0; t < textFrameArray.length; t++) {
                  var rangeArray = textFrameArray[t].parentStory.findGrep();
                  for (var i = 0; i < rangeArray.length; i++) {
                      txt += ('Page: ' + (p + 1) + '   Reference: ' + rangeArray[i].contents + '\n');
          $.writeln(txt);  // Return result to console in ExtendScript
          /* Result
          Page: 1   Reference: 222.333.444
          Page: 1   Reference: 111.222.333
          Page: 2   Reference: 222.222.222
          Page: 2   Reference: 777.222.332
          Page: 2   Reference: 777.222.333
          • 2. Re: Search refereces by grep and get page in file text
            Peter Kahrel Adobe Community Professional & MVP
            It can be much easier. Try this one:
            app.findGrepPreferences = null;
            app.findGrepPreferences.findWhat = '\\d{3}\\.\\d{3}\\.\\d{3}';
            f = app.documents[0].findGrep();
            for (i = 0; i < f.length; i++)
                $.writeln (f[i].contents + ' on page ' + f[i].parentTextFrames[0].parentPage.name);
            The parentPage propert was introduced in CS5. And maybe the $.writeln () should go in a try/catch construct just in case. For CS4 and earlier, which don't know parentPage, use athe findPage function, of which there are sevral versions in this forum.
            Peter
            • 3. Re: Search refereces by grep and get page in file text
              thor2112 Level 1
              Very nice!  Thanks Peter!  :-)
              • 4. Re: Search refereces by grep and get page in file text
                Miguel Otz Level 1
                Thank Peter and thor2112. It's go on, That's good!
                Bye
                Miguel Colmenero
