1 Reply Latest reply on Feb 21, 2008 6:56 AM by Gregory Lafrance
    PopUpWindow for login screen
    satishreddy536
      hello,
      i have a form called EyeNet.mxml
      in that form now i want a popup screen called login.mxml
      when the user runs the application(EyeNet) first login screen shud be appeared
      after user enters the detils into login scren then control shud automatically go into the EyeNet screen
      how to achieve this
        • 1. Re: PopUpWindow for login screen
          Gregory Lafrance Level 6
          I would use a ViewStack:
          ------------------------------ ViewStack.mxml -------------------------------
          <?xml version="1.0"?>
          <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" xmlns:comp="components.*">
          <mx:Script>
          <![CDATA[
          private function selectPortal(event:Event):void {
          if(cmbx.selectedItem.data == "home"){
          portals.selectedChild = home;
          if(cmbx.selectedItem.data == "hr_portal"){
          portals.selectedChild = hr_portal;
          if(cmbx.selectedItem.data == "is_portal"){
          portals.selectedChild = is_portal;
          if(cmbx.selectedItem.data == "pay_portal"){
          portals.selectedChild = pay_portal;
          </mx:Script>
          <mx:ApplicationControlBar width="100%">
          <mx:Label text="Select an intranet portal: " fontSize="12"/>
          <mx:ComboBox id="cmbx" change="selectPortal(event)">
          <mx:Object label="XYZ Intranet Home Page" data="home"/>
          <mx:Object label="Human Resources Portal" data="hr_portal"/>
          <mx:Object label="Information Services Portal" data="is_portal"/>
          <mx:Object label="Payroll Portal" data="pay_portal"/>
          </mx:ComboBox>
          </mx:ApplicationControlBar>
          <mx:ViewStack id="portals" width="100%" height="100%">
          <mx:Panel width="100%" height="100%" horizontalAlign="center"
          backgroundColor="#ccffcc" id="home">
          <mx:Text text="Welcome to the XYZ Corporate Intanet" fontSize="20"
          color="blue"/>
          </mx:Panel>
          <comp:HumanResources id="hr_portal"/>
          <comp:InformationServices id="is_portal"/>
          <comp:Payroll id="pay_portal"/>
          </mx:ViewStack>
          </mx:Application>
          ---------- components/HumanResources.mxml ------------------
          <mx:Panel xmlns="*" xmlns:mx=" http://www.adobe.com/2006/mxml"
          width="100%" height="100%" horizontalAlign="center" backgroundColor="red">
          <mx:Text text="Human Resources Portal" fontSize="20"
          color="blue"/>
          </mx:Panel>
          ---------- components/InformationServices.mxml ------------------
          width="100%" height="100%" horizontalAlign="center" backgroundColor="purple">
          <mx:Text text="Information Services Portal" fontSize="20"
          color="blue"/>
          </mx:Panel>
          ---------- components/Payroll.mxml ------------------
          width="100%" height="100%" horizontalAlign="center" backgroundColor="gray">
          <mx:Text text="Payroll Portal" fontSize="20"
          color="blue"/>
          </mx:Panel>
