5 Replies Latest reply on Feb 11, 2013 12:10 AM by splram
    Installation issue
    invinciblekg
      Hi all,
      I am having some issues in installation of CQ5 .
      When i launch cq5-author-4502.jar file on my windows 7 system, installation doesn't start but a crx-quickstart folder is created.
      I am showing below the log file generated in crx-quickstart folder.
      Please help in troubleshooting.
      Loading instance properties:/quickstart/quickstart-cq5.properties
      Running on a console, won't fork the JVM (use -fork to force forking)
      Using 32bit VM settings
      **** WARNING: insufficent heap memory ******************************************
      The JVM reports 63 MB but we recommend at least 256 MB +/- 20
      Use your JVM's heap size option (like -Xmx256M) to set that size.
      The -fork option (-h explains it) provides appropriate defaults.
      The JVM MBean:Perm Gen reports a maximum size of 64 MB, meets our expectation of 64 MB +/- 20
      Setting system properties from filename 'file:/D:/day/cq5-author-4502.jar'
      System property '-crx.quickstart.server.port' set to '4502' from filename cq5-author-4502.jar
      System property 'sling.jcrinstall.folder.name.regexp' set to '.*/(install|config)(.author)?$' from filename cq5-author-4502.jar
      System property 'sling.run.modes' set to 'author' from filename cq5-author-4502.jar
      System property 'server.ready.url.1' set to '900/120/0 http://localhost:$PORT$/login.html .*(QUICKSTART_HOMEPAGE|CRX_LICENSING_PAGE).*' from filename cq5-author-4502.jar
      System property 'server.ready.url.2' set to '300/40/0 http://localhost:$PORT$/libs/cq/core/content/systemready.txt .*(QUICKSTART_HOMEPAGE|CRX_LICENSING_PAGE).*' from filename cq5-author-4502.jar
      System property 'com.day.crx.launchpad.filters.CRXLaunchpadLicenseFilter.waitForContentPath' set to '/bin/login.html?src=CRXLaunchpadLicenseFilter' from filename cq5-author-4502.jar
      Verbose option not active, closing stdin and redirecting stdout and stderr
      Redirecting stdout to D:\day\crx-quickstart\logs\stdout.log
      Redirecting stderr to D:\day\crx-quickstart\logs\stderr.log
      Quickstart startup at Tue Sep 18 10:51:33 IST 2012
      crx.quickstart.build.number=5.4.0.20110218
      DiskSpaceUtil.getMaxOpenFiles() reports a maximum of 2147483647 open files, meets our requirement (8192)
      PortSelector: Selecting server port from supplied list: 4502
      PortSelector: Trying port 4502
      PortSelector: Successfully bound to port 4502, will use it
      PortSelector: Selected port 4502
      etc/server.xml does not exist, CQSE password not saved
      quickstart.properties not found, not an update
      PreserveExistingFiles: no files to restore from pre-upgrade backup
      System property crx.quickstart.info.jar.name set to file:/D:/day/cq5-author-4502.jar
      System property crx.quickstart.info.work.dir set to D:\day\crx-quickstart
      System property crx.quickstart.info.server.dir set to D:\day\crx-quickstart\server
      System property crx.quickstart.info.server.port set to 4502
      Extracting CQSE distribution...
      Ignored as we're providing a Quickstart-specific variant: D:\day\crx-quickstart\server\server.bat
      Ignored as we're providing a Quickstart-specific variant: D:\day\crx-quickstart\server\serverctl
      Ignored as we're providing a Quickstart-specific variant: D:\day\crx-quickstart\server\start
      Ignored as we're providing a Quickstart-specific variant: D:\day\crx-quickstart\server\stop
      Saving build number in quickstart.properties
      Setting up CQSE webapps and files...
      13 files extracted from jar file
      Extracting static files to workdir...
      31 files extracted from jar file
      Making scripts executable...
      Running chmod +x D:\day\crx-quickstart\server\serverctl
      Failed to set executable mode on scripts: java.io.IOException: Cannot run program "chmod": CreateProcess error=2, The system cannot find the file specified
      Processing updates...
      Updates source: D:\day\crx-quickstart\repository\patches\new
      RunJarOnce INFO: RunJarOnce created, srcFolder=D:\day\crx-quickstart\repository\patches\new, doneFolder=D:\day\crx-quickstart\updates\history
      No update jars executed
      Done processing 0 updates
      sling.repository.url not set, empty in instance properties
      Starting CQSE on port 4502, interface=null...
      Work dir: D:\day\crx-quickstart
      CQSE arguments: [-p, 4502]
      System property server.ready.url.1 defines WaitUrlParams, url=http://localhost:4502/login.html, regexp=.*(QUICKSTART_HOMEPAGE|CRX_LICENSING_PAGE).*, times=900/120/0
      System property server.ready.url.2 defines WaitUrlParams, url=http://localhost:4502/libs/cq/core/content/systemready.txt, regexp=.*(QUICKSTART_HOMEPAGE|CRX_LICENSING_PAGE).*, times=300/40/0
      Waiting for http://localhost:4502/crx (0/900) ...
      Waiting for server installation...
      Retrying http://localhost:4502/crx (ConnectException) (1/900)...
      Retrying http://localhost:4502/crx (ConnectException) (3/900)...
      Retrying http://localhost:4502/crx (ConnectException) (5/900)...
      Retrying http://localhost:4502/crx (ConnectException) (7/900)...
      Retrying http://localhost:4502/crx (ConnectException) (9/900)...
      Retrying http://localhost:4502/crx (ConnectException) (11/900)...
      Retrying http://localhost:4502/crx (ConnectException) (13/900)...
      log4j:WARN No appenders could be found for logger (com.day.commons.httpclient.impl.ProxySelector).
      log4j:WARN Please initialize the log4j system properly.
      Retrying http://localhost:4502/crx (ConnectException) (15/900)...
      Retrying http://localhost:4502/crx (ConnectException) (17/900)...
      Retrying http://localhost:4502/crx (ConnectException) (19/900)...
      Retrying http://localhost:4502/crx (ConnectException) (21/900)...
      Retrying http://localhost:4502/crx (ConnectException) (23/900)...
      Retrying http://localhost:4502/crx (ConnectException) (25/900)...
      Retrying http://localhost:4502/crx (ConnectException) (27/900)...
      Retrying http://localhost:4502/crx (ConnectException) (29/900)...
      Retrying http://localhost:4502/crx (ConnectException) (31/900)...
      Retrying http://localhost:4502/crx (ConnectException) (33/900)...
      Retrying http://localhost:4502/crx (ConnectException) (35/900)...
      Retrying http://localhost:4502/crx (ConnectException) (37/900)...
      Retrying http://localhost:4502/crx (ConnectException) (39/900)...
      Retrying http://localhost:4502/crx (ConnectException) (42/900)...
      Retrying http://localhost:4502/crx (ConnectException) (44/900)...
      Retrying http://localhost:4502/crx (ConnectException) (46/900)...
      Retrying http://localhost:4502/crx (ConnectException) (48/900)...
      Retrying http://localhost:4502/crx (ConnectException) (50/900)...
      Retrying http://localhost:4502/crx (ConnectException) (52/900)...
      Retrying http://localhost:4502/crx (ConnectException) (54/900)...
      Retrying http://localhost:4502/crx (ConnectException) (56/900)...
      Retrying http://localhost:4502/crx (ConnectException) (58/900)...
      Retrying http://localhost:4502/crx (ConnectException) (60/900)...
      Retrying http://localhost:4502/crx (ConnectException) (62/900)...
      Retrying http://localhost:4502/crx (ConnectException) (64/900)...
      Retrying http://localhost:4502/crx (ConnectException) (67/900)...
      Retrying http://localhost:4502/crx (ConnectException) (69/900)...
      Retrying http://localhost:4502/crx (ConnectException) (71/900)...
      Retrying http://localhost:4502/crx (ConnectException) (73/900)...
      Retrying http://localhost:4502/crx (ConnectException) (75/900)...
      Retrying http://localhost:4502/crx (ConnectException) (77/900)...
      Retrying http://localhost:4502/crx (ConnectException) (79/900)...
      Retrying http://localhost:4502/crx (ConnectException) (81/900)...
      Retrying http://localhost:4502/crx (ConnectException) (83/900)...
      Retrying http://localhost:4502/crx (ConnectException) (85/900)...
      Retrying http://localhost:4502/crx (ConnectException) (88/900)...
      Retrying http://localhost:4502/crx (ConnectException) (90/900)...
      Retrying http://localhost:4502/crx (ConnectException) (92/900)...
      Retrying http://localhost:4502/crx (ConnectException) (94/900)...
      Retrying http://localhost:4502/crx (ConnectException) (96/900)...
      Retrying http://localhost:4502/crx (ConnectException) (98/900)...
      Retrying http://localhost:4502/crx (ConnectException) (100/900)...
      Retrying http://localhost:4502/crx (ConnectException) (103/900)...
      Retrying http://localhost:4502/crx (ConnectException) (105/900)...
      Retrying http://localhost:4502/crx (ConnectException) (107/900)...
      Retrying http://localhost:4502/crx (ConnectException) (109/900)...
      Retrying http://localhost:4502/crx (ConnectException) (111/900)...
      Retrying http://localhost:4502/crx (ConnectException) (113/900)...
      Retrying http://localhost:4502/crx (ConnectException) (115/900)...
      Retrying http://localhost:4502/crx (ConnectException) (117/900)...
      Retrying http://localhost:4502/crx (ConnectException) (120/900)...
      Retrying http://localhost:4502/crx (ConnectException) (122/900)...
      Retrying http://localhost:4502/crx (ConnectException) (124/900)...
      Retrying http://localhost:4502/crx (ConnectException) (127/900)...
      Retrying http://localhost:4502/crx (ConnectException) (129/900)...
      Retrying http://localhost:4502/crx (ConnectException) (131/900)...
      Retrying http://localhost:4502/crx (ConnectException) (133/900)...
      Retrying http://localhost:4502/crx (ConnectException) (135/900)...
      Retrying http://localhost:4502/crx (ConnectException) (137/900)...
      Retrying http://localhost:4502/crx (ConnectException) (140/900)...
      Retrying http://localhost:4502/crx (ConnectException) (142/900)...
      Retrying http://localhost:4502/crx (ConnectException) (144/900)...
      Retrying http://localhost:4502/crx (ConnectException) (147/900)...
      Retrying http://localhost:4502/crx (ConnectException) (149/900)...
      Retrying http://localhost:4502/crx (ConnectException) (151/900)...
      Retrying http://localhost:4502/crx (ConnectException) (153/900)...
      Retrying http://localhost:4502/crx (ConnectException) (156/900)...
      Retrying http://localhost:4502/crx (ConnectException) (158/900)...
      Retrying http://localhost:4502/crx (ConnectException) (160/900)...
      Retrying http://localhost:4502/crx (ConnectException) (163/900)...
      Retrying http://localhost:4502/crx (ConnectException) (165/900)...
      Retrying http://localhost:4502/crx (ConnectException) (167/900)...
      Retrying http://localhost:4502/crx (ConnectException) (169/900)...
      Retrying http://localhost:4502/crx (ConnectException) (172/900)...
      Retrying http://localhost:4502/crx (ConnectException) (174/900)...
      Retrying http://localhost:4502/crx (ConnectException) (176/900)...
      Retrying http://localhost:4502/crx (ConnectException) (178/900)...
      Retrying http://localhost:4502/crx (ConnectException) (180/900)...
      Retrying http://localhost:4502/crx (ConnectException) (183/900)...
      Exception in thread "Timer-0" java.lang.IllegalStateException: this writer hit an OutOfMemoryError; cannot commit
      at org.apache.lucene.index.IndexWriter.prepareCommit(IndexWriter.java:3362)
      at org.apache.lucene.index.IndexWriter.commit(IndexWriter.java:3417)
      at org.apache.jackrabbit.core.query.lucene.AbstractIndex.commit(AbstractIndex.java:389)
      at org.apache.jackrabbit.core.query.lucene.VolatileIndex.commit(VolatileIndex.java:141)
      at org.apache.jackrabbit.core.query.lucene.PersistentIndex.copyIndex(PersistentIndex.java:12 8)
      at org.apache.jackrabbit.core.query.lucene.MultiIndex$VolatileCommit.execute(MultiIndex.java :2094)
      at org.apache.jackrabbit.core.query.lucene.MultiIndex.executeAndLog(MultiIndex.java:1115)
      at org.apache.jackrabbit.core.query.lucene.MultiIndex.commitVolatileIndex(MultiIndex.java:11 63)
      at org.apache.jackrabbit.core.query.lucene.MultiIndex.flush(MultiIndex.java:938)
      at org.apache.jackrabbit.core.query.lucene.MultiIndex.checkFlush(MultiIndex.java:1283)
      at org.apache.jackrabbit.core.query.lucene.MultiIndex.access$100(MultiIndex.java:81)
      at org.apache.jackrabbit.core.query.lucene.MultiIndex$1.run(MultiIndex.java:337)
      at java.util.TimerThread.mainLoop(Unknown Source)
      at java.util.TimerThread.run(Unknown Source)
      Retrying http://localhost:4502/crx (ConnectException) (185/900)...
      Retrying http://localhost:4502/crx (ConnectException) (188/900)...
      Retrying http://localhost:4502/crx (ConnectException) (190/900)...
      Retrying http://localhost:4502/crx (ConnectException) (192/900)...
      Retrying http://localhost:4502/crx (ConnectException) (194/900)...
      Retrying http://localhost:4502/crx (ConnectException) (196/900)...
      Retrying http://localhost:4502/crx (ConnectException) (198/900)...
      Retrying http://localhost:4502/crx (ConnectException) (201/900)...
      Retrying http://localhost:4502/crx (ConnectException) (203/900)...
      Retrying http://localhost:4502/crx (ConnectException) (206/900)...
      Retrying http://localhost:4502/crx (ConnectException) (212/900)...
      Exception in thread "Thread-0" java.lang.OutOfMemoryError: Java heap space
      Sep 18, 2012 10:56:44 AM it.tidalwave.imageio.util.Logger info
      INFO: Installing RAWProcessor...
      INFO: Installed RAWProcessor
      RAWProcessor succesfully installed
        • 1. Re: Installation issue
          Wile-the-Coyote
          looked like it is a memory issue.
          go to $your_CQ5_installation_folder\author\crx-quickstart\bin
          edit the quickstart.bat
          ::* default JVM options
          set CQ_JVM_OPTS=-Xmx512m -XX:MaxPermSize=128M
          • 2. Re: Installation issue
            invinciblekg Level 1
            Hi
            Thanks for replying Wile
            But in quickstart folder , there is no bin folder.
            One bin folder is present in server folder but it contains bootstrap.jar ( \crx-quickstart\server\bin\bootstrap.jar).
            • 3. Re: Installation issue
              marsh1979
              hi,
              Are you able to resolve this issue? This is quite annoying as CQ is just playing up and installation seems to be failing without any good error messages.
              I am getting below messages
              Messages in stderr log:
              Retrying http://localhost:4502/login.html (503)...
              http://localhost:4502/login.html timed out after 900 seconds
              Did not get expected content at server URL, server might still be starting up
              Please try http://localhost:4502/login.html again later
              (1962 seconds since startup)
              Server not ready, browser not launched
              Messages in server log file
              10.02.2013 09:31:41 *ERROR* webapp-CRX Launchpad Webapp: ERROR: Error starting slinginstall:D:\Adobe\author\crx-quickstart\launchpad\startup\15\org.apache.sling.runmode -2.0.3-tlp-R818849.jar (org.osgi.framework.BundleException: Unresolved constraint in bundle org.apache.sling.runmode [18]: package; (&(package=org.osgi.framework)(version>=1.4.0)))
                        at org.apache.felix.framework.Felix.resolveBundle(Felix.java:3263)
                        at org.apache.felix.framework.Felix.startBundle(Felix.java:1597)
                        at org.apache.felix.framework.Felix.setActiveStartLevel(Felix.java:1077)
                        at org.apache.felix.framework.StartLevelImpl.run(StartLevelImpl.java:264)
                        at java.lang.Thread.run(Unknown Source)
              10.02.2013 09:31:41 *MARK * servletengine: http listener on address 0.0.0.0, port 4502 started
              10.02.2013 09:31:41 *MARK * server: Server ready
              10.02.2013 09:31:42 *MARK * webapp-Content Repository Extreme: Start servlet 'JSPServlet'
              My environment details are given below
              Windows 7, 64 bit
              Java Version 1.7
              CQ Version: cq-wcm-quickstart-5.3.0.20100127
              I did not see if windows 7 is supported in the release notes. Any idea what is going wrong here
              • 4. Re: Installation issue
                Gregor Zurowski Level 1
                @marsh1979: CQ 5.3 is not compatible with Java 7 (see http://dev.day.com/docs/en/cq/5-3/deploying/technical_requirements.html), and the logs you posted seem to display the erroneous behavior when installing CQ 5.3 with Java 7. Installing (and running) with Java 6 should solve your problem.
                • 5. Re: Installation issue
                  splram Level 1
                  Set the memory options in server.bat file available under crx-quickstart/server folder, modify the parameters just below ::* Memory settings
                  The parameters are:
                  set JVM_MINHEAP=-Xms256m
                  set JVM_MAXHEAP=-Xmx512m
                  set JVM_PERMGEN=-XX:MaxPermSize=512
