0 Replies Latest reply on Feb 20, 2008 1:00 PM by JasonSapp
    Problem handling SimpleTypes in WSDL to ActionScript generator
    JasonSapp
      I've generated a very simple web service where one of the Operations uses a "SimpleType" that happens to be an Enumeration. I've simplified the service down to it's simplest form, so that my problem can be reproduced and I've attached the associated WSDL. The bottom line is that I successfully generate the Action Script classes, but the resultant generated Action Script web service class (in the generated EchoImplService.as file) ends up with a method call on it with the following signature:
      public function echo (echo:Echo, echo:String):AsyncToken
      My problem is the fact that there is no generated class called "Echo". Hmmmm.... Any ideas?
      Jason Sapp
