3 Replies Latest reply on Sep 18, 2012 6:15 AM by Harm Millaard
    Scaling Up 1080p Video in 720p Sequence?
    Taverino Level 2
      All of my footage for a project is shot in 1080p. The final media will be delivered in 720p. I want to scale up some of the footage (jump cut) within the sequence. What is the best way to ensure that the scaled-up clips are at maximum image quality? Does it matter if the sequence is 720p or 1080p? Thanks for any help.
        • 1. Re: Scaling Up 1080p Video in 720p Sequence?
          Harm Millaard Level 7
          If you disable Scale to frame size for the selected clips, there is no scaling and you maintain maximum quality and it appears to be upscaled, but is not. You can then use Motion/position to get the exact image you want without quality loss. As soon as you set the scale over 100% you will lose quality. Iy you use scale below 100%, you are scaling down, not up.
          • 2. Re: Scaling Up 1080p Video in 720p Sequence?
            Taverino Level 2
            Thank you, Harm, for the very helpful response. So to generalize this situation, if I disable "Scale to Frame Size" (which appears to be the default setting), then is the full original resolution available to all effects?
            In the situation I describe using your suggestion, does it make a difference whether the sequence is 720p or 1080p if I am going to render at 720p? Thanks.
            • 3. Re: Scaling Up 1080p Video in 720p Sequence?
              Yes it makes a difference. When you start with a 1080 sequence all you can do to avoid loss of quality is to not use scale at all or scale down, in which case you introduce black bars.
              If you start with a 720 sequence and do not use Scale to frame size, you can scale down to 720  or anything between 1080 and 720 format and recompose your clips.
