2 Replies Latest reply on Sep 18, 2012 8:38 AM by wfzen
    return for text does not display correctly in Notepad
    wfzen Level 1
      I used myString = myString & temp & return to generate text with multiple lines. It displays correctly in MS Word, Write, but they are all packed together in one line when opened with NotePad on Windows.
      What command do I need to add for it to display correctly in NotePad and MS Word, etc word processor programs?
      Same with import with FileIO, text made with Notepad would have any extra return character at the beginning. I need to delete the first character in order for it to display correctly in Director.
      What is the best approach dealing with return key in Director?
        • 1. Re: return for text does not display correctly in Notepad
          James Newton, ACP Level 3
          On Macintosh, new lines are defined by one character: RETURN
          On Unix, new lines are defined by one character, called LineFeed: numToChar(10)
          On Windows, new lines are defined by both characters: RETURN&numToChar(10)
          You can use the ReplaceAll() handler below to convert a string in Mac format so that it will appear correctly in NotePad:
          myString = ReplaceAll(myString, RETURN, RETURN&numToChar(10))
          on ReplaceAll(aString, aSubString, aReplacement) ---------------------
            -- INPUT: <aString> is the main string to search in
            --        <aSubString> is a string which may appear in <aString>
            --        <aReplacement> is a string which is to replace all
            --         occurrences of <aSubString> in <aString>
            -- OUTPUT: returns an updated version of <aString> where all
            --         occurrences of <aSubString> have been replaced by
            --         <aReplacement>
            if aSubString = "" then
              return aString
            end if
            tTreatedString = ""
            tLengthAdjust  = the number of chars of aSubString - 1
            repeat while TRUE
              tOffset = offset(aSubString, aString)
              if tOffset then
                if tOffset - 1 then
                  put chars(aString, 1, (tOffset - 1)) after tTreatedString
                end if
                put aReplacement after tTreatedString
                delete char 1 to (tOffset + tLengthAdjust) of aString
              else -- there are no more occurrences
                put aString after tTreatedString
                return tTreatedString
              end if
            end repeat
          end ReplaceAll
          When you read the string back in from the hard disk, you can use this handler to convert a string in any format to a string in Mac/Director format:
          myDirectorCompatibleString = NormalizeText(myStringInUnknownFormat)
          on NormalizeText(aString) --------------------------------------------
            -- INPUT: <aString> should be a string
            -- ACTION: Removes DOS or UNIX line endings and replaces them with
            --         MAC line endings
            -- OUTPUT: Returns a string with no LF characters
            if not stringP(aString) then
              return ""
            end if
            vLF   = numToChar(10)
            vCRLF = RETURN&vLF
            if aString contains vLF then
              if aString contains vCRLF then
                aString = ReplaceAll(aString, vCRLF, RETURN)
              else
                aString = ReplaceAll(aString, vLF, RETURN)
              end if
            end if
            return aString
          end NormalizeText
          • 2. Re: return for text does not display correctly in Notepad
            wfzen Level 1
            James, thanks a lot for you help. The function does exactly what I need.
