6 Replies Latest reply on Sep 18, 2012 11:01 AM by LRK 2
    IDCS6 :: Renumbering Form Fields
    LRK 2 Level 2
      Renumbering Form Fields in InDesign CS6
      I created a nine page interactive form document with all elements inserted. Each form field was inserted as a box and converted to an interactive text box.  At some point there were copies of copies. Some were deleted, some were moved around.
      Is there an easy way to recalculate or renumber the form fields to get them in the right order? In other words, eliminate all the box numbers that were deleted, and get the numbers to flow without skipping?
      Thank you!
        • 1. Re: IDCS6 :: Renumbering Form Fields
          Steve Werner Adobe Community Professional & MVP
          I think what you're asking for is called setting the Tab Order. This is the order of fields when you tab from field to field in a PDF file.
          I believe there are two ways to do this. The first is to use the Tab Order command. Select Object > Interactive > Tab Order > Set Tab Order. I've never worked on more than a one page form so I don't know if that is a page-by-page command. Obviously this would be easier if you named each of your form fields and not numbered them.
          The second way, which Sandee Cohen demonstrated in a webinar I watched, is to use the Articles panel. You'd create a new article by dragging the first field to the Articles panel, then keep dragging them in tab order.
          I've not used this method, but she said in her presentation that you must do two things when choosing File > Export > Adobe PDF (Interactive): You need to check Create Tagged PDF and you need to check Use Structure for Tab Order.
          Good luck.
          • 2. Re: IDCS6 :: Renumbering Form Fields
            LRK 2 Level 2
            Steve, Thank you so much! I just upgraded to DWCS6 this week for a particular job. This is very helpful. I'll give these a try and let you know how it work.
            • 3. Re: IDCS6 :: Renumbering Form Fields
              LRK 2 Level 2
              The Articles > Tab Order Palette seems to be the answer I needed. I am most grateful for your help.
              Thank you!
              • 4. Re: IDCS6 :: Renumbering Form Fields
                LRK 2 Level 2
                Suggestion for Developers
                Looks like there is a bit of a glitch. When you double click on a Text Field in the Articles Palette and then click on another, the page jumps around even when zoomed out. I want to hold it in place in order to keep track of the Fields I am targetting as related to previous fields.
                Hopefully that minor issue, which can mess with your head will be fixed in an update.
                • 5. Re: IDCS6 :: Renumbering Form Fields
                  LRK 2 Level 2
                  Just one more question if I may…
                  Is there a script or some other method that will allow you to rename all selected fields numerically based on the order they are listed in the Articles Tab Order Palette?
                  • 6. Re: IDCS6 :: Renumbering Form Fields
                    LRK 2 Level 2
                    Clarification: Authomatically rename all selected fields based on a starting number you assign
