6 Replies Latest reply on Sep 20, 2012 2:52 PM by Rick Gerard
    What is going on!!!!!!!!!!!!!!!!!!!!!!
    belordmedia Level 1
      I have a
      Mac Pro 2X 3.06 GHz 12core intel Xeon 2012, 32GB ram1 SSD Drive 520 gbts +3 X 3tbts Hrd Drives. ATI  Radeon HD 5870HD
      Why is after effects CS6 so painfully slow.  To my mind, 5.5 on a 2006 machine was faster
      Rendering a simple 3D text is very slow making the software unusable.
      Forget about doing any real work!!!!!
      is it me????
      M
        • 1. Re: What is going on!!!!!!!!!!!!!!!!!!!!!!
          Greg Baber Adobe Employee
          You say you are doing "simple 3D text"?
          Are you in Classic 3D or Ray-Traced 3D?
          RayTrace is going to be slower as it is raytracing all of the text -- you can reduce the rays being used, or you can switch to Classic 3D unless you need extruded text.  I usually recommend using Classic 3D unless the effects you want to use require the Ray-Traced mode.
          • 2. Re: What is going on!!!!!!!!!!!!!!!!!!!!!!
            Properly set up and using the same settings I'm finding CS6 faster than CS5.5 or CS5 on all of my Macs'.
            Please check your settings sounds like you have ray traced rendering selected.
            • 3. Re: What is going on!!!!!!!!!!!!!!!!!!!!!!
              belordmedia Level 1
              Hello Guys
              Many thanks for your help.
              Maybe I should share all my settings  within the AE panel and, that way it may be easier for people to point things out?,
              ____________________
              Hard Stuff
              Mac Pro 2X 3.06 GHz 12core intel Xeon 2012, 32GB RAM. 1 SSD Drive 520 gbts +3 X 3tbts Hrd Drives. ATI  Radeon HD 5870HD
              After Effects CS6
              Vers:11.0.1.12
              All programs are installed on a SSD Drive 520GB
              AE>>>PREFERENCE>>>Previews
              Adaptive resolution limit 1/8
              CPU Imformation
              Texture Memorie 768MB
              Ray tracing is CPU
              GPU for what I understand is not supported on the AT Radeon HD 5870 OpenGL Engine (bummer)
              Version 2.1 ATI-1.0.25
              Total Memory 1.00GB
              ___________________________
              Media & Disk Cache
              Enable Disk Cache ON
              Maximum Disk Cache 60 GB
              Folder is on another Internal ATA Drive
              Database is on the same ATA Drive
              Cache is on the same ATA Drive
              Memory
              Installed Ram 32GB
              RAM reserved for othe applications 4GB
              Render Multiple Frame is ON
              Installed CPU 24
              CPU Reserved for other applications 2
              Ram Allocated per background CPU 2GB
              Actual CPUs used 12
              Hope this will help.
              Kind Regards
              Michel
              • 4. Re: What is going on!!!!!!!!!!!!!!!!!!!!!!
                I do have one thing to point out - Multiprocessor support should be tweaked so that you have 3 GB per CPU.  Best method is to limit the CPUs used by AE.
                • 5. Re: What is going on!!!!!!!!!!!!!!!!!!!!!!
                  belordmedia Level 1
                  Hello Greg,
                  The 3 GB per CPU makes a substential difference to the rendering time.
                  I would have thought the more the cpu ther better. well, wrong again.
                  Thanks for the tip
                  Michel
                  • 6. Re: What is going on!!!!!!!!!!!!!!!!!!!!!!
                    CPU optimization is hard. You can easily choke the system by allocating too much memory and too many processor cores to the process. Other things always have to run in the background just to keep things like delivering the frames to the hard drive working smoothly.
