2 Replies Latest reply on Sep 19, 2012 4:15 AM by m_s_moran
    Radio button in Acrobat Javascript Dialog
    m_s_moran
      Newbie, but not afraid to strut my ignorance, if it will get me help.  I want this script to launch as a custom calculation script for a dynamic stamp. I just can't get a value for the radio button> This is where I'm at:
      __________________________________________________________
      var dialog = {
        retString: "",
        commit:function (dialog) { // called when OK pressed
          var results = dialog.store();
        description:
          name: "Document Sealing",    // Dialog box title
          elements:
              type: "view",
              elements:
                  type: "radio",
                  item_id: "sub1",
                  group_id: "g1",
                  width: 200,
                  height: 25
                  type: "radio",
                  item_id: "sub2",
                  group_id: "g1",
                  width: 200,
                  height: 25
                  type: "radio",
                  item_id: "sub3",
                  group_id: "g1",
                  width: 200,
                  height: 25
                  type: "ok_cancel",
                  ok_name: "Ok",
                  cancel_name: "Cancel"
      if(event.source.forReal && (event.source.stampName == "#ERUOSX5CkPZixTOImPQJqA"))
        if ("ok" == app.execDialog(dialog))
          if("sub1" == 1)
          var cMsg = "Not Sealed";
          event.value = cMsg;
      Any guidance would be most appreciated.
      Mike
        • 1. Re: Radio button in Acrobat Javascript Dialog
          Before the dialog create a variable that will hold the user's selection:
          var sealing;
          Then in the commit event of the dialog you check which radio-button is selected and assign a value to this variable accordingly, like so:
              if (results["sub1"]) sealing = 1;
              else if (results["sub2"]) sealing = 2;
              else if (results["sub3"]) sealing = 3;
          Then after the dialog has been closed you use the value of this variable in the rest of your script, such as:
          if (sealing==1) {
            event.value = "Not Sealed";
          • 2. Re: Radio button in Acrobat Javascript Dialog
            m_s_moran Level 1
            Try67, your suggestion worked perfectly. Many thanks for you assistance.
            Mike
