3 Replies Latest reply on Sep 19, 2012 10:05 AM by rdolgov
    Blank spaces
    MyStreetUSA
      How do I remove blank spaces between the fields, i.e. I removed the lines and page break and cannot get the information on the pages to line up under each other; what I'm getting is 3/4 blank page, then the survey continues.
      Any ideas before I have to re-type it all?
        • 1. Re: Blank spaces
          rdolgov Adobe Employee
          Can you please send a screenshot of the problem? Do you see empty space on authoring and on fillable side?
          Roman
          • 2. Re: Blank spaces
            MyStreetUSA Level 1
            Sorry, don’t know how to post PPT in the forum – the 3 questions are:
            1.     Blank spaces, slides 1 & 2
            Form layout is correct on the web
            Pdf form forced ¾ page blank space
            2.     Login pages, slides 3 & 4
            After log-in an error page inserts which switches to the adobe forms home
            page after 1-2 seconds
            3.     Adding a company email return address, slide 5
            How do I add company email address to show in From response
            Thank you for your help!
            Kristi Grogan
            • 3. Re: Blank spaces
              Hi Kristi,
              Can you please send me the slides via email: rdolgov@adobe.com so i better understand the questions. And if possible can you also send me the form design file (you can export via File->Export Design File... menu).
              In general, PDF layout can be different from Web layout because of different page split. You  can use Page View in the Design Tab to see how fields would be divided into the pages.
              Roman
