1 Reply Latest reply on Sep 20, 2012 11:12 AM by sinious
    Test movie not working correctly
    rusido Level 1
      When I haven't saved an as3 file in flash pro cs6 I can test a movie by pressing ctrl+enter, but when I save the movie and I want to test it, it doesn't test my movie?
        • 1. Re: Test movie not working correctly
          sinious Most Valuable Participant
          If you click somewhere inside the interface (on the selection tool or on something on the stage, etc) does this issue still occur? Sometimes panel context is an issue. For example if you edit a property in the properties panel and hit tab to go to the next property, until you click something else in the interface to remove focus from that property it won't work. Also pressing escape to finish editing the property sometimes isn't enough, you need to click something in the interface to make shortcut keys active again.
