5 Replies Latest reply on Sep 20, 2012 1:08 AM by Bill joy
    JS :Object is Invalid
    Bill joy Level 1
      Hi all
      I want to insert footnote at the end of text.
      When i run my java script give error object is invalid at line no 7.
      #target indesign
      var myDocument = app.documents.add();
      var myTextFrame = myDocument.pages.item(0).textFrames.add();
      myTextFrame.geometricBounds = ["6p", "25p", "30p", "30p"];
      myTextFrame.contents = "Indesign";
      var word  =myTextFrame.parentStory.words.item(1);
      var insertionPoint=word.insertionPoints.item(-1);    // give error  at this line Object is invalid
      var footnote=insertionPoint.footnotes.item(1).add(at(1701733408));
      footnote.setContents("FirstFootnote");
      myDocument.FootnoteOptions.setEosPlacement(1);
      Thanks.
        • 1. Re: JS :Object is Invalid
          Jump_Over Level 5
          Notice, that your frame words count = 1 (words[0]):
          var word  =myTextFrame.parentStory.words.item(0);  // there is only one word so words.item[1] is invalid
          hope...
          • 2. Re: JS :Object is Invalid
            Bill joy Level 1
            Thanks Jump_Over for reply
            There is another problem in my Script in the selection of Image place in textframe. I am not understand this problem also. It give error  Undefined is not an object   in 5th line.
            myTextFrame = myDocument.pages.item(1).textFrames.add();
            myTextFrame.geometricBounds = ["20p", "25p", "30p", "35p"];
            myTextFrame.place(File("/C/version.jpg"));
            var graphic=myTextFrame.allGraphics.firstItem;
            graphic.select("SelectionOptions.REPLACE_WITH");  // give error Undefined is not an object
            graphic.geometricBounds = ["20p", "25p", "30p", "35p"];
            if I use this line
            var graphic=myTextFrame.allGraphics.item(1).select("SelectionOptions.REPLACE_WITH");
            then it give error
            myTextFrame.allGraphics.item is not a function
            Thanks.
            • 3. Re: JS :Object is Invalid
              Harbs. Level 6
              allGraphics is an array, not a collection.
              Use var graphic=myTextFrame.allGraphics[0];
              or
              var graphic=myTextFrame.graphics.item(0);
              or
              var graphic=myTextFrame.graphics.firstItem;
              • 4. Re: JS :Object is Invalid
                Jump_Over Level 5
                var graphic=myTextFrame.allGraphics.firstItem;   // supposed to be firstItem(), if isValid but...
                allGraphics is an array, not a collection, so there is no valid firstItem() method.
                use graphic[0] to refer to first element of array.
                By the way, still watch your (1) vs (0) indexes ==> first is (0)
                hope...
                • 5. Re: JS :Object is Invalid
                  Bill joy Level 1
                  Thaks Harbs for reply
                  work sucessfully.
