1 Reply Latest reply on Sep 19, 2012 9:28 PM by megharajdeepak
    passing an argument to a skin
    developer_ethan
      I have a custom skin that basically draws a gradient background on a button.
      I want to use the same skin, but, change the colors of the gradient background for each button. The hostCompnent.property lines
      causes  a compiler error:
      1119: Access of possibly undefined property borderFillGradient1 through a reference with static type spark.components.supportClasses:ButtonBase
      What am I doing incorrectly.
      Thanks in advance.
      Here is my custom button component:
      <s:Button xmlns:fx="http://ns.adobe.com/mxml/2009"
                                       xmlns:s="library://ns.adobe.com/flex/spark" xmlns:controls="myconrols.*" skinClass="assets.skins.MyButtonSkin">
          <fx:Declarations>
              <!-- Place non-visual elements (e.g., services, value objects) here -->
          </fx:Declarations>
          <fx:Script>
              <![CDATA[
                  public var mainFillColor1:uint;
                  public var mainFillColor2:uint;
                  public var borderFillGradient1:uint;
                  public var borderFillGradient2:uint;
          </fx:Script>
      </s:Button>
      Here is my custom skin
      <s:SparkButtonSkin xmlns:fx="http://ns.adobe.com/mxml/2009"
                   xmlns:fb="http://ns.adobe.com/flashbuilder/2009"
                   minWidth="5" minHeight="18"
                   alpha.disabled="0.5">
          <fx:Metadata>
              <![CDATA[
               * @copy spark.skins.spark.ApplicationSkin#hostComponent
              [HostComponent("controls.MyCustomButton")]
          </fx:Metadata>
          <!-- states -->
          <s:states>
              <s:State name="up" />
              <s:State name="over" />
              <s:State name="down" />
              <s:State name="disabled" />
          </s:states>
          <!-- border -->
          <s:Rect height="100%" width="100%" radiusX="6"
                  top="0" right="0" bottom="0" left="0">
              <s:fill>
                  <!-- gradient fill colors - default ratios are 0,1 -->
                  <s:LinearGradient rotation="90">
                      <s:GradientEntry color="{ hostComponent.borderFillGradient1}"/>
                      <s:GradientEntry color="{ hostComponent.borderFillGradient2}"/>
                  </s:LinearGradient>
              </s:fill>
          </s:Rect>
          <!-- inner fill -->
          <s:Rect height="100%" width="100%" radiusX="5"
                  top="1" right="1" bottom="1" left="1">
              <s:fill>
                      <s:GradientEntry color="{ hostComponent.mainFillColor1 }"/>
                      <s:GradientEntry color="{ hostComponent.mainFillColor'}"/>
                  </s:LinearGradient>
              </s:fill>
          </s:Rect>
          <!--- @copy spark.components.supportClasses.ButtonBase#labelDisplay  -->
          <s:Label id="labelDisplay"
                   textAlign="center"
                   maxDisplayedLines="1"
                   horizontalCenter="0" verticalCenter="1" verticalAlign="middle"
                   left="8" right="8" top="2" bottom="2" color="0xffffff">
              <s:filters>
                  <s:DropShadowFilter distance="1" blurX="0" blurY="0" color="#000000" alpha=".4" angle="270"/>
              </s:filters>
          </s:Label>
      </s:SparkButtonSkin>
        • 1. Re: passing an argument to a skin
          megharajdeepak Level 1
          Hi there..
          color property is style  and hence you need to create a style rather than property.
          Instead of :
          delcare them as styles like this:
                  [Style(name="mainFillColor1", type="uint", format="Color")]
                  [Style(name="mainFillColor2", type="uint", format="Color")]
                  [Style(name="borderFillGradient1", type="uint", format="Color")]
                  [Style(name="borderFillGradient2", type="uint", format="Color")]
          And use it in your code like this:
          <s:GradientEntry color="{ hostComponent.getStyle('mainFillColor1') }"/>
          You could also use css and delcare your colors there and use only one skin for all your buttons and handle their colors in css.
          Cheers!
          Deepak
