3 Replies Latest reply on Sep 22, 2012 8:33 AM by r_tist
    drop cap rule question
    r_tist Level 1
      In book layouts, what if the first character on the new chapter page body copy is a quotation mark vs. a letter? - I'm guessing that I apply the drop cap style/technique to both. Visually, it seems to look pretty good. But what is the rule of thumb in this case?
      Thanks!
        • 1. Re: drop cap rule question
          TᴀW Adobe Community Professional & MVP
          There is a convention cited in various style guides that in such a case
          the opening quote is omitted. Best of luck getting that past your
          editors. I've never managed to. Visually it's probably the best solution.
          Instead, I reduce the opening quote till almost regular text size and
          then baseline-shift it upwards so that it sits in a visually acceptable
          spot. Some kerning may also be necessary.
          For me, it rarely works to set it at full drop-cap size. I suppose it
          might depending on the typeface.
          Ariel
          www.FreelanceBookDesign.com
          • 2. Re: drop cap rule question
            Michael Gianino Level 4
            Or you could kick the can down the road and rewrite the sentence to move the quote to the inner part of the sentence.
            • 3. Re: drop cap rule question
              r_tist Level 1
              Yes, I reduced the quote size to about the ordinary text size and baseline shifted it. It looks professional. Thanks for the advice!
