4 Replies Latest reply on Sep 20, 2012 7:29 AM by SamuelXiot
    null object reference while call other compenet function
    SamuelXiot
      I have create the following function in component A(which is productDetailComp)
      public  function  createProductDetailItem(productdetail:Productdetail):void{
                  productdetailService
      .createProductdetail(productdetail);
      .commit();
      and in the component B, I call the function via
      var productdetail:Productdetail = new Productdetail();
      productDetailComp.createProductDetailItem(productdetail);
      but, why the following error pop up while invoking the createProductDetailItem() function? Need to create a instance for the function or the component productDetailComp??
      TypeError: Error #1009: Cannot access a property or method of a null object reference. at productDetailComp/onEdit()[C:\Users\School\Adobe Flash Builder 4.6\FYPadminSideV3\src\productDetailComp.mxml:80] at productDetailComp/__button2_click()[C:\Users\School\Adobe Flash Builder 4.6\FYPadminSideV3\src\productDetailComp.mxml:250]
        • 1. Re: null object reference while call other compenet function
          BBlommers Level 2
          I'm assuming you're calling this function via
          var productdetailComp:ProductdetailComp = new ProductdetailComp();
          What does line 80 look like, of productDetailComp?
          Did you initialize the productDetailService-object?
          • 2. Re: null object reference while call other compenet function
            SamuelXiot Level 1
            if (isNew == true){//***********************************************
            one statment and nothing.
            the following code is
                                        pc.createProductDetailItem(productdetail);
                                        Alert.show("this is a new record");
                                        this.currentState == "Viewer"
                                    }else{//************************************************************
                                        pc.updateProductDetailItem(productdetail);
                                        Alert.show("this is an update");
            • 3. Re: null object reference while call other compenet function
              SamuelXiot Level 1
              and the productDetailService is declared in the <fx:Ddeclarations>
              <productdetailservice:ProductdetailService id="productdetailService"
        fault="Alert.show(event.fault.faultString + '\n' + event.fault.faultDetail)"
        showBusyCursor="true"/>
              • 4. Re: null object reference while call other compenet function
                SamuelXiot Level 1
                Soleved
                by create a instance for the service and everything run perfectly
