Hy!
I have been using Adobe Captivate 6 for some days now. Recently a problem has occurred: In the screencapture I have taken, I open some calendar. In the tool itself everything works properly, but in the outupt (in pdf or htm but not in mp4) it is different - either I have black pixels on the spot where something should happen, or the screen is afterwards reduced to the size of the calendar.
What is my problem? And how may I help it?
Kind regards and thanks
Zechner Nicole
Hello,
Welcome to Adobe Forums.
Does this issue occurs on a blank project at well
Do you have Windows or MAC
As you mentioned "Recently", Did it work earlier ?
Did you try to publish .htm or .pdf to a different location ?
Vikram
Hy!
The issue does not occurr in a blank project - moreover, it does not
occurr in the project when I create it. It comes into it if I replay it
often, to look if everything works correct.
I use Windows 7.
And yes I did try to publish it in a different location, but that would
not help it.
Thanks.
Hello,
Did you trying playing that .MP4 file on a different computer ?
Can you share that .MP4 file with the CP6 project (tcssup@adobe.com)
Vikram
