2 Replies Latest reply on Sep 20, 2012 7:31 AM by the_wine_snob
    image duration in premiere pro cs5
    chri13386 Level 1
      i'm editing a video in 1280x960 with pr pro cs5, squared pixels, 25 fps.
      i would set the image duration to 1,5 sec, but premiere doesen't allow it, and I can't set the image duration in the interval from 1,25 sec to 2 sec; I can set a duration lower than 1,25 sec, or higher than 2 sec.
      does anyone know why?
        • 1. Re: image duration in premiere pro cs5
          SAFEHARBOR11 Most Valuable Participant
          Assuming you are setting the still image duration under Edit / Preferences / General, please keep in mind that the value entered must be in FRAMES and not SECONDS
          Jeff Pulera
          Safe Harbor Computers
          • 2. Re: image duration in premiere pro cs5
            the_wine_snob Level 9
            As Jeff points out, in Edit>Preferences, you would set your Stills Duration to 37, or 38 Frames, and would have you 1-1/2 sec. Duration at 25 FPS. In CS 5 and later, you can change the Duration of multiple Stills in the Project Panel, by Selecting them and Rt-clicking on them. Note: if those Stills are on the Timeline, Delete them from the Timeline, change the Duration and then drag them back to the Timeline.
