Hello,
I am making the native extension for Map in android. But I am facing the problem that I am not able to generate the debug.keystore for the android project as it's a library project,Thas why my native map doesn't shows up ,instead it shows blank tiles and Google logo in the bottom .Please help me with this.
Maybe is too late but i'll find the way on Adobe flash builder 4.7:
Debug->Debug-Configuration->Customize launch
here you can see the parameter [-keystore] and get the debug-certify (in my case: C:\Program Files\Adobe\Adobe Flash Builder 4.7 (64 Bit)\eclipse\plugins\com.adobe.flexide.multiplatform.android_4.7.0.349722\resources\debug-certificate-android.p12 )used for flash builder debugs release!
notice that certify CAN be changed . In case you need the store pass the default is "debug" or you can get it on the "show Command" button
By the way ( it seem you are using Google API ) make sure you are using the proper package name: when you release an [-target apk-debug] from ADT command line your APK will be modified your <id> package from <id>com.example.application</id> to <id>com.example.application.debug</id> so, make sure to include the ".debug" prefix on the Google's console if you need it.
Happy codding
This is the newest update:
With Android Studio 2.3 (maybe earlier version do the same thing), ~/.android/debug.keystore will be created for you at your first debug build and the alias/pass for debug key is androiddebugkey/android.
If you want to replace the Flash Builder default keystore, you should customize the launch by replace the parameters:
-keystore HOME/.android/debug.keystore -storetype jks -storepass android -alias androiddebugkey
Don't forget to clean your workspace after re-configure.
