3 Replies Latest reply on Nov 25, 2012 11:17 PM by rajnikids
    Spell check in static pdf
    vinoth_mannu Level 1
      Hi All,
      Is there is any spell checking plugin or javascript available in acrobat.
        • 1. Re: Spell check in static pdf
          George_Johnson MVP & Adobe Community Professional
          If you're asking about spell checking text that's part of the regular page contents, as opposed to annotations or form fields, then you can use JavaScript to a degree. For example, see: http://livedocs.adobe.com/acrobat_sdk/9.1/Acrobat9_1_HTMLHelp/wwhelp/wwhimpl/js/html/wwhel p.htm?href=JS_API_AcroJS.88.1.html#1515776&accessible=true
          Example 2 in particular.
          If you're asking about something else, post again with more information.
          • 2. Re: Spell check in static pdf
            rajnikids Level 1
            Hi Geroge,
            The script below is from Acrobat, which runs the spell check for the entire page contents.
            But, I m thinking to include the specific words in this script, which should be showed as error while running script and annonated.
            Can you help me.
            /* Spell Check a Document */
                      var ckWord,numWords, i, j;
                      for (var i = 0; i < this.numPages; i++ )
                                numWords = this.getPageNumWords(i);
                                for ( j = 0; j < numWords; j++)
                                          ckWord = spell.checkWord(this.getPageNthWord(i,j))
                                           if ( ckWord != null )
                                                    annot = this.addAnnot
                                                     page: i,
                                                     type: "Squiggly",
                                                     quads:  this.getPageNthWordQuads(i,j),
                                                     author: "A. C. Acrobat",
                                                     contents: ckWord.toString()
            thanks & regards,
            rajnikanth
            • 3. Re: Spell check in static pdf
              rajnikids Level 1
              Hi George,
              Many apologise for the wrong request.
              I m just reiterating my request.
              But, I m thinking to include the specific words in this script, which should not be showed as error while running script and should not suggested in annonations.
              many thanks
              rajnikanth
