6 Replies Latest reply on Sep 20, 2012 8:36 AM by SJRiegel
    Lines form Cels and Tables
    Fer Parker
      I'm having some problens with lines in tables...
      I typed my whole text in a text program and imported it in InDesign CS5
      Now, i need to edit some tables from the text here, but i keep falling in errors...
      Here are the Cell and Table options i set for u to take a look....
      https://lh5.googleusercontent.com/-oBpTNkvYvUQ/UFskDIs1AlI/AAAAAAAABws/27FO6j3bobI/s1133/Indesign-table-lines.png
      First I enter the cell options. In the cell stroke i remove the 2 inner lines, then i set 0 pt for weight and choose none for the cell tuype.
      Then i go to Table Options. I need weight 2, choose the type i want and the color black.
      After all that, i export to pdf to take a look and i see the lines between cell are still there, althou i set then as 0 and no type.
      I tried to change orders, setting the Table Options first and then the Cell Options, same problens
      Take a look at these tables....
      https://lh3.googleusercontent.com/-NwdUj5Xvy4I/UFsmpfUuiUI/AAAAAAAABxY/jGccRMNRyKo/s875/Untitled-2.png
      The first one has the lines between rows and columms, these lines i must remove, as u can see in the second one.
      Is there anything i'm forgeting?
      Please i beg for help. The book i'm doing is full of tables and they need to be in same format type...
