2 Replies Latest reply on Sep 21, 2012 5:37 AM by vepoo
    Read imported EPS file
    vepoo
        I'm trying to read some EPS information from InDesgin Script, but I'm finding some differences from EPS Specification (http://partners.adobe.com/public/developer/en/ps/5002.EPSF_Spec.pdf)
        According with EPS Specification, the first four bytes from a EPS file must be C5D0D3C6.
        But if I create a Word document with MathType Equations, and import this document in my InDesign book, and check the embedded files. I found that the four first bytes are D7CDC69A, and all EPS comments (I want read the MathType xml associated with the EPS) are unreadable, but if I look carefully for the file, I see that the information is there.
      There is another type of EPS file that are not on the EPS Specification I linked here? How can I read this file?
        • 1. Re: Read imported EPS file
          Techi Panda Level 2
          Hi vepoo
          i guss your looking for something like this
          function read_basevalue()
          var read_file = myPicFile.open ('r');
          do{
          myLine = myPicFile.readln();
          var regular_expression = new RegExp("%%Baseline: ");
          var match_re=myLine.match(regular_expression);
          if (match_re!=null)
          my_base_value = myLine.split(' ')[1];
          while(myPicFile.eof == false);
          myPicFile.close();
          • 2. Re: Read imported EPS file
            vepoo Level 1
            Hi Techi Panda!
            I'm already using this code. And it's useful for some cases. But in the case I told, the EPS file store the information of a WMF file. So I cannot read the information with this code!
            There is another way to open this file and read the WMF metadata?
